Superior specs of the base LE/SE trims
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Jan 7, 2023.
  1. Gokhan
    Gokhan Senior Member
    4,655
    1,866
    Paramount CA
    The specs on the Gen 4 Prius were identical across the trims. However, in the Gen 5 Prius/Prius Prime, the base LE/SE trims have vastly superior specs:
    • fuel economy
      • 57/56/57 mpg city/highway combined (LE)
      • 52/52/52 mpg city/highway combined (XLE/Limited)
    • EV range
      • ~ 42 mi (SE)
      • ~ 38 mi (XSE/XSE Premium)
    • turning circle
      • 34.4 ft (LE)
      • 35.4 ft (XLE/Limited)
    • tires
      • 195/60R17 (LE)
      • 195/50R19 (XLE/Limited)
    • tire failure (conflicts with info on toyota.com)
      • spare tire (LE)
      • no spare tire but tire-repair kit (XLE/Limited)
    • height
      • 55.9 in (LE)
      • 56.3 in (XLE/Limited)
    • ground clearance
      • 5.6 in (LE)
      • 6.0 in (XLE/Limited)
    • coefficient of drag (Cd)
      • 0.27 (LE)
      • ~ 0.29 (XLE/Limited)
    • EPA cargo volume (seats up; manufacturer estimated; trim info seems to be switched in error—see this)
      • 23.8 ft³ (LE)
      • 20.3 ft³ (XLE/Limited)
    • curb weight
      • 3097 lb (LE)
      • 3164 lb (XLE)
      • 3219 lb (Limited)
    #1 Gokhan, Jan 7, 2023
    samsprius1, CR94 and mjoo like this.
    49,489
    what makes the LE lower?
    are the bodies different?
    are you sure these specs are right for prime? weight seems odd
  3. Tideland Prius
    16,155
    Weight listed is just the Liftback
  4. Trollbait
    11,560
    The specs weren't identical across the gen4 trims.
    The larger wheels on some of the higher trims change the turning radius. Likewise, they would reduce fuel economy. It is just that different wheel sizes doesn't require separate testing by the EPA, and Toyota kept the curb weights close enough for that to not force separate mpg figure posting. This is true of all cars with different tire sizes sold in the US.
    The L Eco had a larger cargo volume. It also had a much better mpg rating. It didn't have a spare, but neither did some of the higher trims.
    The tires on the 17in wheels are a little smaller in overall diameter. That drops the ground clearance and height.
    The difference in Cd could be because of the different wheels. Has Toyota posted Cd figures? I've only seen the 0.27 mentioned in an article.
    rampante550 likes this.
  5. Gokhan
    4,655
    1,866
    Paramount CA
    Smaller-overall-diameter tires.
  6. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Why does the XLE and Limited have less Cargo Volume?
    Is it because of the hokey "MacGyver-like" cargo cover?
    In my Gen4, I typically keep my rear seats down.
    Still, it's great to have the stow-away retractable cargo cover, for those times I want to use it.
    It's a shame that Toyota didn't offer a similar Gen5 cargo cover as an option.
  7. Gokhan
    4,655
    1,866
    Paramount CA
    There are some errors in the specs provided by Toyota. There are three cargo/spare options (spare tire (less cargo volume), tire-repair kit with storage bins (less cargo volume; same as with spare tire), and tire-repair kit without storage bins (more cargo volume)), but it is not clear which trim gets which option.
    Gen 5 Prius/Prius Prime: poor fuel economy, poor choice of colors, poor choice of packages/options | Page 7 | PriusChat
  8. prius16
    462
    243
    New England
    2022 Prius Prime
    Thanks for the link and info! (y)
    Weird that they have different options for the rear. It seemed like they were being even more careful to contain design and build costs.
    Gokhan likes this.
  9. Gokhan
    4,655
    1,866
    Paramount CA
    My guess is that LE will get a smaller cargo volume with a spare tire or storage bins & a tire-repair kit below deck. XLE/Limited with get a larger cargo volume with only a tire-repair kit below deck. However, it could also be the other way around.
    I am getting the LE, and I would rather get the spare tire in case I need it. I would have no usage for the storage bins under deck.
    Toyota probably started production on Prius on January 2. If they fill the boat by mid-January, it could dock in LA in late January.
    Prius Prime production could start circa April 1.
    #9 Gokhan, Jan 8, 2023
  10. Trollbait
    11,560
    Cost and weight. You have to provide a place to store it. The cover they did use looks like it can just lay flat on the floor when not needed. A retractable cover built into the side might be the best solution. Somebody has this, so could be patent protected.
    From the photos and videos, the floor deck and cubicles looks thrown in, like the old Prime's battery. They all use the same sheet metal. Any differences are plastic pieces and some bolts. The white cubby plastic was likely chosen for cost. the costs are likely no different than having different inserts for spare or no spare in other models.
    Plus, the Prime's battery might extend rearward a bit from under the seat. These options are likely considering that.
    The reviews appear to all be upper trims from the wheels, and those that shown the under floor cargo space have the deck with cubicles.
    For managing hopes, I'd say the spare is going to be an option for the LE.
  11. Gokhan
    4,655
    1,866
    Paramount CA
    This is according to the official Canada specs:
    • EV range
      • 40 mi (SE)
      • 33 mi (XSE/XSE Premium)
    https://attachments.priuschat.com/attachment-files/2023/01/231422_E02E6936-5155-47EE-AF3D-4B83322D20CE.jpeg
  12. Gokhan
    4,655
    1,866
    Paramount CA
    Wait, the reviews are for the upper trims, yes, but they show a raised deck (B1 (with storage trays under deck) or B2 (with spare under deck)) option:
    So, it looks like the upper trims might come with a spare, and LE/SE will not come with a spare but will come with more cargo space and less curb weight. In that sense, LE/SE will be like LE Eco.
    However, we have not seen any cargo-area pics for the LE/SE, and they may also have the same B1/B2 option instead of the A option (a lowered deck with no storage trays or spare).
    #12 Gokhan, Jan 8, 2023
  13. Sue Case
    Sue Case Junior Member
    89
    44
    Maryland
    2023 Prius Prime
    So possibility throw in the spare tire as extra weight to reduce MPG on upper trims. Sure seems like we're robbing Peter here to pay Paul.
    I'll take the spare tire over a can of "inflate foam" any day. And do check that foam can expiration date since who knowshow long they last .
    Now I'd still like the 17 inch wheels versus 19 and the smaller size might counter the weight of the spare. Can we horse trade here Toyota?
    If we can then give the synthetic leather upholstery seats versus cloth on the base trim. I'll even give back the spare for Mr. Foam.
    CR94 likes this.
  14. Trollbait
    11,560
    Except, the spec listed on the US site lists the LE as having over 3 more cubic feet of cargo space. That only happens without a raised deck option.
    Adding a spare that doesn't have a major impact on the car interior will be easier than adding on to the gen4 Prime.
    All the extras of the higher trims adds weight. The larger screen, the camera for the digital mirror, that digital mirror, the seat heaters, the fancier more comfy seats, etc. Those all add to the weight gain for a higher trim. The Softex fabric could weigh more than the cloth. The spare tire came out to counter that.
    The a la carte car feature method results in higher prices. In the early 2000's, Volvo still had it, and they charged something like $1000 to just access the second tier options that included things like cruise control. It's an outrageous example, but it exists because the paperwork of taking custom orders and making sure the factory gets it right adds more work.
    The trims and packages system may not meet customers wants and needs 100%, but it saves hundreds to thousands of dollars over ordering exactly what you want. Savings which go to fixing the things you aren't happy with if you want.
  15. Gokhan
    4,655
    1,866
    Paramount CA
    So, no place to mount a spare in LE/SE then.
  16. bisco
    49,489
    when there are a glut of primes on dealer lots, you'll be able to make a wheel deal
  17. Trollbait
    11,560
    There's the extra 3.something cu.ft. of extra space at the bottom of the cargo area.
  18. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Yet 50-60 years ago, when basic cars cost ~$2000, the U.S. manufacturers could deliver a car with the exact combination of options you ordered with no extra charge. The only drawback was the 6-week wait.
  19. Tideland Prius
    16,155
    The extra charge was the cost of the a la carte options. Also, way fewer available options than now (aside from some domestics with an insane number of colour choices)
  20. Gokhan
    4,655
    1,866
    Paramount CA
    But does it have a spare mount? You would also have to buy the mounting hardware and correct deck.
