Support Thread for Speed Lock Override sold in the PC Shop
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cproaudio, Oct 8, 2011.
  1. Yes I want to bypass that damn speed lock.
    87.5%
  2. No, It'll be worst than texting while driving.
    1.2%
  3. No, but I still wanna see how it's done.
    10.3%
  4. I don't see a reason listed so I'll list mine own.
    0.9%
  1. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Good points. I didn't think about the USB, since my model doesn't have it. I rarely use my phone, and usually don't even have the BT active on my phone. Usually, if my phone rings, I let it go to VM, turn on BT, and call the person back if I deem it to be that important.
    I can see the usefulness in the bypass, but it's a little too much for my ability with soldering (I've tried before, I sucked) or the removing of the unit for my usage of everything.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I have some news. I'm considering making the bypass kit available through the Priuschat Shop.
    2 people like this.
  3. kmkremer
    kmkremer Member
    227
    30
    San Diego
    I'm in!​
  4. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    i'd be interested, depending on the price, I almost bought the coastal tech one years ago...
  5. cproaudio
    2,401
    762
    CA
    Some more details
    I am still in the planning stage. I will make 2 types. The difference between the two is the switch. V1 uses a simple 2 position On-On switch but the operation is bypass on and bypass off. You don't have to buy it if you can build it, just follow the directions in post 1. V3 uses a 3 position switch On-Off-(On). The operation is bypass on, bypass off and 1 minute timed. To turn off the the timer off early, turn the bypass on then off. The timer is user adjustable between 1 and 90 seconds. I thought I had mine timed at 1 minute but after reviewing my videos, mine was timed 45 seconds. I will preset the timer to approximately 1 minute. Initially there was a V2 without the ability to turn the timer off via the on-off switch. I have decided to scrap that version because I have a feeling that whoever bought that, would rather have the V3.
    As of now, I have no plans on making the schematic for V2 or V3 available. Those who are electronically inclined should be-able to figure it out.
    I'm still sourcing the materials and finalize the schematic on V3. I'm having trouble finding a decent On-On switch and On-Off-(On) switch. If you guys can recommend an acceptable looking switch please let me know. Remember, it has to fit into the blank hole and look nice. As of now, I will be using rocker switch for the on-on and mini rocker switch for the on-off-(on) switch. Since there's no way I can source the OEM 5 pin male and female plug and the male and female cigarette lighter plug, this kit will not be plug and play. You'll have to cut the VSS wire and T tap the power and ground wires to install it, see installation guide at the bottom of post 1.
    I will be building the kit by hand and only during my spare time so quantity will be limited. It won't look industrially built like the prestigious Society.
    I have not set the price yet but Version 1 will be less than $100 and Version 3 will be less than $150. I won't have anything available for at least 2 months. This will give me the time I need to source the materials and actually building them or even change my mind and forget the whole thing if the comments are discouraging. I also need to know which version you would likely to buy so I can estimate on buying the additional parts needed to make version 3.
    The profits from this project will go toward buying a more reliable plugin conversion kit.
    Any inputs are welcome. Thanks.
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I already have the prestige society version of this, but I've been curious to know whether it will work in the 2012 PIP HDD model, which I think is the same as in the new Model v, and possibly the Camry. Is it too soon to know whether the wiring is the same, at least for this purpose?
  7. DonVentura
    DonVentura SoCal Prius Driver
    78
    Ventura, CA
    I'd buy one...like version 3, but for $100. I'd buy version 1 today
  8. cproaudio
    2,401
    762
    CA
    I believe the signal is the same. I just don't know which wire is the VSS. Knowing Toyota, it's probably violet just like every other Prius. I have a question for your Prestigious Society bypass. Why does it have an input and output for the GPS antenna and the reverse wire? There's also a 3rd wire on that 5 pin plug that was looped into the PS bypass. Do you know what's the reason for it? Beat-Sonic's version does not have that.
    I think every one would appreciate V3 but the cost would discourage them from buying it. The one I'm using is V2 and have been using it for almost a year now. One thing I hate on my that I didn't include in the first place was the ability to turn off the timer. Because of that, I don't use the timer as much I liked to. I mostly use the On-Off side of the switch. This is one of the reason why I scrap the V2. Once I finish V3 design and build the prototype, I'm pulling the V2 out of my car.
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I'd definitely go for one too for when I get my plug in as long as it would let me use the dvd player to continue to play dvd's once the car is in motion... Not for me while driving as I know many would be quick to jump in and mention but rather for my son to watch while on a road trip womewhere...
  10. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Sorry, I don't know any of the technical details for the PS bypass. It's a very easy install, and yes it is very nice to be able to turn it back off as soon as you are done inputting (with just a poke of the same button that turns on the timer). I guess I'll send them an email and see if they know whether it pins out and works the same on the new systems.
  11. cproaudio
    2,401
    762
    CA
    The plugins have factory DVD option?
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I thought the radios in the 2012's that had the upgraded units played DVD's while the car was parked.
    Tideland Prius always gets these specifics right, let me direct him to this question lol.
  13. Tideland Prius
    16,609
    Paradox is right. The cars with the Premium HDD headunit will have the ability to play DVDs while in Park. I'm not sure why it isn't mentioned in the brochure or features list but I do recall Toyota mentioning that they will add this feature to their top unit.
    Also, Dianne mentions it in her Prius v test drive
    http://priuschat.com/forums/prius-v-main-forum/99284-mini-drive-mini-review-v-three.html#post1408246
  14. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Thanks Tideland, you're my back-up when I'm unsure of something I'm pretty sure on lol.
  15. cproaudio
    2,401
    762
    CA
    I was talking about standard Prius not the v
  16. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    We're talking about that too. It should be any of the new top end HDD based units in the Prius, PiP, v...
    He used the v as an example since he had a thread in which it was mentioned it worked in a v, but the plug in will be the same and the standard Prius too, again IF you get the high end radio.
  17. Tideland Prius
    16,609
    ^ what he said.
    Any vehicle with the Premium HDD nav should have it.
  18. michaellam510
    michaellam510 Junior Member
    MA
    Wow,
    I would love to, all that for one fuction bypass?
    Just looking at it gives me a brain freeze... hahaha:mod::eek:
  19. jc562
    jc562 Junior Member
    27
    lb to sd CA
    wow that looks like alot of cables and work
  20. cproaudio
    2,401
    762
    CA
    If you're interested in overriding the navigation speed lock but don't want to build it or can't build it, wait til next month. I'm working with Danny to put the navigation override on the Priuschat Shop some time in December.
    Here are more exciting updates!
    I'm ordering all the parts, and have redesigned the bypass. The instruction in post 1 is now called Revision 1 and it's about as basic as you can get. I'm on revision 2 now. V1R2 adds a couple of more features. First, when the bypass is off, there's no current draw. If you look at the schematics in post 1, you'll notice that the 555 timer gets its power directly from the cigarette lighter. This means that when you turn on the ACC or power up the car, the 555 timer starts to draw power. The power draw is extremely small, less than 1 watt, but there's still a draw. If you left your car on ACC-ON, the ACC-ON will kill your 12V battery before the V1R1 will. The second added feature is when the bypass is on, an LED on the switch lights up to let you know that it is on. In order to add these 2 features, I had to use a relay so turning on and off the bypass will emit a relay clicking sound. V1R1 does not have this sound. The only clicking sound is from the switch. Because I added a relay for V1R2, the current draw, when activated, will be more than V1R1. However it's still extremely small at about 1 watt.
    V3 also got similar features and is now called V3R2. When the bypass is off, there's no current draw. When it's on either ON or 1 minute timed, I estimate the draw to be 1-5 watts due to additional relays used. V3R2 will also have a 2 color LED by the switch to let you know whether if the bypass is in constant ON or 1 minute timed. Again, no plans on making the schematics available because people already have enough trouble making sense of the V1R1.
