Supposed inverter replacement. Had a check hybrid system warning on the display.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mypriuscious, Jul 2, 2015.
  1. bisco
    51,937
    so you're all good now?:)
  2. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Yessir!
    SM-N910V ?
  3. JC91006
    16,768
    8,565
    This is all free?
  4. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    No. 860.00$$
    SM-N910V ?
  5. Patrick Wong
    18,210
    6,510
    What is the part number/description of the replaced part and the labor hours charged? $860 is a really high repair price.
  6. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    G92Z047011
  7. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    They also represented the remotes so the doors auto unlocked when I walked up to the car.
    SM-N910V ?
  8. Patrick Wong
    18,210
    6,510
    RogerHq likes this.
  9. JC91006
    16,768
    8,565
    that parts for a highlander
  10. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    The receipt says it's 300.
    SM-N910V ?
  11. Patrick Wong
    18,210
    6,510
    Also for 3G Prius.
  12. JC91006
    16,768
    8,565
    wow, I would think there's plenty of those units floating around the used marketplace....or parts dumpsters
  13. Patrick Wong
    18,210
    6,510
    I think this assembly is for the three system main relays and the resistor used to apply DC high voltage to the inverter gracefully. When the Prius is first made READY, the resistor allows the inverter capacitors to charge up without absorbing excessive current. Once a short period has elapsed, the resistor is shorted out so that the inverter will receive full available power from the traction battery.
    So the question is why 3G taxicabs need to have this replaced. My guess is that the assembly may overheat as it does carry substantial current and high voltage. This is not an issue that I've noticed with either Classic or 2G Prius.
  14. bisco
    51,937
    $300. for part, and $560. for labor? how many hours is that?
  15. JC91006
    16,768
    8,565
    I would think it's the same labor charge as replacing the hv battery
  16. bisco
    51,937
  17. mrbigh
    3,686
    699
    Long Island, NY
    $560.00 for labor seems a bit in the high side................probably 4 hs labor
  18. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    With the recall on software update done, toyota increases your inverter warrenty to 15 years unlimited miles. I recieved letter from toyota with a sticker which is supposed to go over warrenty on my warrenty card and it clearly says warrenty extended to 15 years unlimited miles.
  19. Mendel Leisk
    41,457
    By Toyota's description "excessive idling", and the mention of taxis, I'd expect they mean just leaving the car on, for hours at a time, maybe running AC too, situations where the engine periodically cycles on.
  20. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Now that you say that I recall reading the same thing.
    Umar Ali likes this.
