Supposed seal vaccum line?
Discussion in 'Gen 3 Prius Main Forum' started by le baguette, Jun 21, 2022.
  1. le baguette
    le baguette New Member
    australia
    2013 Prius Plug-in
    i-Tech
    Hi All,
    First thread and already searched. I have the 2012 Japanese import Prius and found the bit of vacuum(maybe) line is not sealed or plugged.
    What does the bit in the red circle do and should I plug it? Is it causing issue if not plugged?
    Thanks all for the help
    52,858
    are you having performance issues or trouble lights?
  3. ChapmanF
    19,026
    That coolant tee was made, in some versions, with a white air-bleed valve there, which you could open to release air while filling the engine coolant.
    Other versions of that tee are without the bleed valve.
    If you had one of the with-valve versions and took the valve out, you would have a serious leak of red coolant there.
    So I am guessing you simply have the without-valve version. Unless coolant is gushing out.
  4. le baguette
    australia
    2013 Prius Plug-in
    i-Tech
    Thank you sir. Looks like this is the right answer
  5. le baguette
    australia
    2013 Prius Plug-in
    i-Tech
    Not really apart from car jumps when ice is turned on when parked my parking brake will make a noise
  6. bisco
    52,858
    those are normal, believe it or not
  7. Mendel Leisk
    42,349
    Pull that bit of hose off? As @ChapmanF says, it's likely the non-venting styling coupling. Venting style has a whilte plastic knurled cap you can unscrew, and a spigot for coolant to then flow.
    le baguette likes this.
