Survey: Oil consumption vs build dates
Discussion in 'Gen 3 Prius Main Forum' started by StephenJ, Aug 21, 2017.
  1. Stangar
    Stangar Active Member
    174
    175
    Palmdale, CA
    2011 Prius III (purchased new)
    Build date: 01/11
    171,000 miles (Mainly highway driving in high desert of Southern California)
    Burns no oil (I changed the oil 3 times in the first 1500 miles. (250 mi, 500 and 1500))
    No problems: original brakes, original wheel bearings, I did clean EGR once
    Original tires (Yoko's) went 105,000 miles.
    Oil changed every 5000 mi with Mobil 1, 0-20W and Mobil 1 filter
    I use the "0-20W" whether it's Summer, 112 deg F. or Winter, 20 deg F.
    m.wynn, orenji and Bay Stater like this.
  2. Mendel Leisk
    42,354
    Kind of a flush?
  3. Stangar
    174
    175
    Palmdale, CA
    Yes! I believe it works on most every ICE. At least in my mind.
    However, I recently purchased a new motorcycle and did the same procedure and it does burn a little oil (at 5500 miles). But it's the anomaly.
  4. hayden55
    hayden55 Member
    115
    48
    Oil change at 119k. 11k miles on this oil change. 5 Quarts in. 2.75 Quarts out. Thats about 2qt even consumption for 10k miles. No engine braking used... BUT a lot of 100 mph interstate driving. For like three hours sustained. So it looks like oil consumption goes up a bit when load is increased. Only 0.25 quarts off the stick though so im impressed. Looking like 5 quarts and a filter is a great way to go.
  5. hayden55
    hayden55 Member
    115
    48
    Also I'd like to see people dump their oil back into their 5 quart jugs and start measuring oil consumption as there isn't a such thing as perfect ring seal. There will be oil consumption.
  6. Mendel Leisk
    42,354
    I catch the drain oil with a large funnel on a No-Spill container, which has gradations down the side. Means no cleaning out drain pans (if you do), and is handy for checking oil consumption. Here's our daughter's Pilot drain, spec quantity is 4.3 liters, she never checks it:
    hayden55 and m.wynn like this.
  7. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    2010 Prius II (purchased used, it was a rental car)
    230,000 miles (Mainly highway driving)
    Burns 1/3 quart every 5K change interval.
    I check the oil level every couple of gas stops.
  8. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Just curious....how is the mpg while driving 100 mph?
  9. hayden55
    hayden55 Member
    115
    48
    ~27 mpg lol! (on my scan gauge so like ~28.5 on dic)
  10. Stangar
    174
    175
    Palmdale, CA
    100 mph? Hmmm, . . . did Arkansas disband their Highway Patrol or are you one?
    hayden55 and Mendel Leisk like this.
  11. MelonPrius
    839
    516
    Nevada
    I'm impressed that our Prii can drive 100 mph sustained on the highway. I've hit 100 mph going down a steep mountain pass without taxing the engine (gliding with the gas pedal lightly pressed, preventing a traction battery charge) and it was smoother than I anticipated.
    Bay Stater likes this.
  12. hayden55
    hayden55 Member
    115
    48
    A lot of prayer, luck, and a Valentine V1 is all you need. That and well it seems like most people ignore Prius in general when looking for speeding cars in general... I kid you not.
    In my old 2010 Mustang GT with no cats, loud mufflers, pushing like 110-115db at full tilt boy you dont understand how many cops would follow me. But even then pretty much from 18-21 when I sold the car I went 95 mph 200 miles all the way from my hometown to college and was only ever caught once. Ended up asking for a civil penalty and just paying the 170 fine and moving on. Uh... I guess to show how quick that is the trip is 3 hr 10 min and I could regularly make it in 2 hr 15 - 20 min. Even though road construction or non 70 mph zones.
    Cops here really aren't using laser so that helps. Seems like they have it but for the most part they prefer to sit in the median and blast k or ka. Only on occasion does a smart one flick it on and off to radar.
    Only time ive ever seen a guy actually have a laser gun in his hand I was going 95 in the Prius, had my eyes peeled, saw him in like a split second, and slammed on the brakes and got it down to 69 mph. He pulled out slowly and followed me for like half a mile way back but ended up fading off. I honestly think he didn't believe his gun when he saw it. He for sure zapped me with that laser gun though. hahaha
    For the most these highways im running good lord are so friggin empty.... so it makes it easier.
  13. hayden55
    hayden55 Member
    115
    48
    Its not bad I usually just end up having to smooth out the hilly sections so im not riding the rev limiter the whole time, but instead if the hill is really big ill stay under like 4200 and balance out the up and down hills so I feel less like the motor is going to pop. But on flats and smaller inclines its cake.
