Suspect wheel bearings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C-in-DC, Jul 8, 2023.
  1. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    https://youtube.com/shorts/zUVhhLDvVH0?feature=share4
    Yeah it's the rear wheel bearing. Look how hard it is to turn.
    I bought a carquest brand. It has a 3 year warranty. I'm pretty sure something else will take the car out before then.
  2. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Let us know how the install goes.
  3. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    Carquest? Another cheapo brand. You should have check autozone....
    I hear nothing in the video and can't tell anything. Maybe the brake pads are rubbing?
    You really have to remove the caliper so the wheel has nothing touching the rotor.
  4. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Changed the driver side wheel bearing, and all four rear brake pads. I regret not getting the NSKs since that’s what I removed and found to be grinding. I think the passenger side is going to give out soon as well. It’s clicking a little when I spin it.
    Gotta drive 80 to check to see if everything is okay in my opinion but its pretty much done.
  5. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    I’m going hold on to the old hub just in case it was a mistake to swap it out. It was hard to spin compared to the new one but it’s not grinding as much as when it was on the car.
  6. Eddie25
    503
    213
    MI
    You didn't have to beat the crud out of it to get it out?
  7. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    No, fewer than five whacks with the smallest hammer I have(16 0z) got it out. The rotor was rusted on and took longer to remove.
  8. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    this has sound
  9. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Old wheel bearing off the car. Nsk aisin so I guess it's oem. 245,000 was a good run.
  10. ASRDogman
    8,047
    4,078
    I hear background noise.
    If you can feel and hear it, that's all that matters.
    It's always best to change them in pairs, like struts and shocks.
    And with those miles, surely the other one is bad also...
  11. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    other rear wheel bearing is bad and probably causing some drag. Don’t have money for another bearing right now. Maybe in a few weeks.
    Got an alignment today. Here’s the report. Anything odd in the report?
    ASRDogman likes this.
  12. Eddie25
    503
    213
    MI
    The Aisin part is the speed sensor and I think multiple brands do that (according to photos). I'm curious about NSK now, also made in Japan, and cheaper. I wonder if that really is OEM? Anyone know for sure?
    How long have you had the car?
  13. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    11 years.
    I had some bearings changed in 2019 but I don’t know on which wheels. Probably the front two.
