Suspected Battery Issues, but ...
Discussion in 'Gen 2 Prius Fuel Economy' started by Iria, May 26, 2012.
  1. Iria
    Iria New Member
    32
    So my wife's MPG has gone down from mid- to high-40s to barely 40. We've taken it to the dealer and they charged us $120 to run a check and said there was nothing wrong, adding that if there was something wrong with the battery I'd get a warning light, anyway.
    So, took her car to get some gas for it and coffee for me ... battery meters was about 75% full when I took off. About a half mile later I noticed it had DROPPED to 40 percent. At that point I filled it up.
    When I started it up, I noticed it was now in the purple range. It stayed that way until I got home (after stopping for coffee, too).
    Total trip is only about 1.5 miles.
    This has been a fairly typical scenario lately, but this was certainly more extreme.
    So I think there is something wrong with the way the batteries are charged or the batteries themselves. Toyota disagrees (car is still under warranty).
    I DID read another post here that said that the reg. old 12v battery could have something to do with it. She has sched. maint. soon so we are changing that then, but I do not know why it should matter.
    Ideas? Recourse?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You do not give us any clue what car you own, let just pretend it is a Prius of some sort, you are on PriusChat.
    A 12 volt battery can fail in many ways, SOME of those failures can cause the charging subsystem to attempt to recharge the 12 volt battery whenever you are in Ready. This can cause a dip in MPG such as you see. Perhaps the simplest test for a bad 12 volt battery is to run the power windows with the car NOT in Ready. If they are very slow, you want a new battery.
    We have no idea how old your car or battery is but on most cars, after 4 years, your battery is on borrowed time. The Prius is actually kind to batteries and if you never left lights on you may still have the original 12 volt battery.
    I recommend the Optima Yellowtop over the Toyota OEM battery.
    If you Prius is 2004 or newer, this is a good choice.
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 +
    For 2003 and before
    Optima battery and installation kit for Prius 2001 to 2003
  3. richard schumacher
    7,682
    1,064
    United States
    If the 12V battery is about to die it can cause odd symptoms. If yours is the original 6+ years old battery it is already elderly. Prius doesn't monitor the 12V battery at all, and a dealer diagnosis can easily give a false positive for it.
    The good news is that you can check it yourself in a few minutes with no tools (skip the first few paragraphs of verbiage down to "DO-IT-YOURSELF TEST PROCEDURE"):
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
    The high-voltage traction battery is closely monitored by the car. If it is about to die you will get warning messages and trouble codes that should allow a dealer to diagnose it very quickly, so I wouldn't worry much about that possibility yet.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    We clearly both wrote at the same time, but Richard did a better job than me. At least we don't disagree.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Please post your location as well, as this has a major impact on the advice that can be dispensed (temperature, terrain, warranty, independent shops, etc).
    If your car is more than 4 years old, then replace your 12V battery out of hand.
    If you park an older car in the heat of the day with a fully charged battery, the battery may overheat. In such a case, there is a significant change in the amount boost and regen that the battery will supply/receive, making MPG suffer. If you hear the battery fan running in the back, particularly upon startup, then you know there's a problem but there's not much you can do about it, until the car actually sets a code for a bad cell.
  6. Iria
    Iria New Member
    32
    Sorry, I wrote it very early in the morning my time and didn't have any coffee. It's a 2008 Prius. SF Bay Area, so pretty temperate environment. Right now, neither cold nor hot. Only about 42000 miles on it.
    OK, so it seems that most think that the 12V may have something to do with it.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Four years is a little early for a 12 volt battery, but some have to be less than average for average to work. Richard linked to a nice test for first thing in the morning.
  8. olerox
    olerox Junior Member
    65
    Oregon
    HTML:
    Hi Iria, I completely agree with the above advisors. The Prius 12v aux battery is an odd entity, once its weakened or 'elderly' it requires more frequent charging, more ICE running and then it makes the ecu act senile. Since you have scheduled maintenance I'd grab a new 12v battery and then you can relax for another 4-6 years. Around $300.
    I just replaced my 12v batt last week with an Optima yellow top. Its an easy and clean DIY job if you are inclined. You can order at elearnaid or Advance Auto Parts ($200) and have it delivered free to your door within a week. Make sure you print out the discount coupons.
  9. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    If you are handy, this Optima fits just perfectly
    Optima DS46B24R, available on line for about $190 and a $25 rebate.
  10. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Short trips will cause this (both low MPG and dropping of SOC). Has your typical journey changed at all recently?
    You should check the 12V battery voltage after sitting overnight. Check both the no-load voltage and when running the headlights. This will give us a good idea of the health (or otherwise) of your battery.
