Suspension component torque specs?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by farmecologist, Jun 13, 2018.
  1. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Thanks for all the reply's! ( sorry, I forgot to list axle nuts...but I did get them...see ain't I smart? :D )
    The axle nuts I got are part # 9008017238
    The one question I have is it seems like everyone punches out the old 'locked' nut...but replaces it with a 'regular' ( non-locked ) nut..correct? I.e. - there is no need to 'lock' the new nut...right? o_O
    Thx for the help guys! I'll need it. (y)
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I punched the nut with a chisel;).
    I didn’t want to risk the nut walking out on its own:whistle:.
    I made sure it’ll stay right where I put it:).
    The socket is a 30 mm and 12 point, so that’s the only non spec tool you’ll need (get one at the local auto parts store);).
    I’m sure you have a punch or chisel lying around to keep that hub nut in line(y).
    farmecologist likes this.
  3. farmecologist
    1,960
    1,801
    Southern MN
    Ok but lots of the vids I've watched on the topic seem to omit 'locking' the axle nut...or maybe I fell asleep. :whistle:
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I know it was dimpled when I did the work, so I just “left it as I found it”;).
    But the axle has the gap to do this, and the manual calls out to, so I followed the procedure :).
    When does this work begin for you:whistle:?
  5. Mendel Leisk
    42,341
    Do you guys have air tools?
    farmecologist and Raytheeagle like this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Nope;).
    Only hot air powered:oops:.
    But I eat my wheaties before a maintenance day(y).
  7. farmecologist
    1,960
    1,801
    Southern MN
    Ok...I'm still a bit in the dark about how to do this nut locking though ( ok that didn't sound good ). Any instructional videos, etc...that you know of?
    Parts are on order...so I'd like to start in the next couple weeks. I'm going to start with the drivers side first because of the lower control arm access issue on the passenger side.
    No air tools but I do have this really nice electric impact wrench :
    However, I prefer to do it by hand if I can. I also prefer not to use my riding mower..and prefer to shovel snow by hand even though we have a snow blower. Yes, the neighbors think I'm nuts but it is good exercise! (y)
    Raytheeagle and Mendel Leisk like this.
  8. farmecologist
    1,960
    1,801
    Southern MN
    Alright...this video has a nice view of how to lock the new axle nut :
    Now I get it...you just dent the outer edge. Looks like nearly any punch can work to do that.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    When you take the brakes and rotors off, you’ll see a slot cut into the axle ;).
    Use a drill and appropriate sized bit to clear the old punched axle nut.
    Upon reassembly, Once you have confirmed that the new hub bearing assembly is properly seated (peak your head around and ensure the tapered lip full engages the housing), tighten the axle nut to 160 foot pounds (that’s what’s in the manual, but my torque wrench only goes to 150 so I went til I got a click then out a bit more into the torque).
    Once that is done, find the slot and take a chisel or punch and hammer a flat spot into the slot;).
    You got this(y).
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Yup, simple;).
    I’m sure you have something lying around that will work:).
    Good video (y).
  11. farmecologist
    1,960
    1,801
    Southern MN
    Speaking of torque wrenches...when I replaced the struts recently...I had a tough time torquing up the strut bolts that connect to the steering knuckle. My current wrench just wouldn't do an adequate job ( similar to Ray.... too short and it only goes to 150 ).
    Since I'll have to do this again..and will need it for the axle nut, I ordered this baby :
    Hey it's 'fathers day'..so why not! :D
    Mendel Leisk and Raytheeagle like this.
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    That should work;).
    But that is a premium price:cool:.
    Maybe being close to the 49th parallel has some disadvantages :(.
    But you’ll be able to get the torque spec (y).
  13. Mendel Leisk
    42,341
    You can never have enough torque wrenches. I'm hoping to get a 1/4" in inch/pound range, for upcoming bday. (y)
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I have the 1/4,3/8 and 1/2 inch variety and it still seems like I’m missing something :whistle:.
    But 99% of what I need is met within these ranges so I’ll take it(y).
    farmecologist and Mendel Leisk like this.
  15. Mendel Leisk
    42,341
    Looks like a very solid wrench, and comes with extension and reducer.
    Just editorial: he's using it to break the nut loose?
  16. padroo
    padroo Senior Member
    2,763
    2,253
  17. farmecologist
    1,960
    1,801
    Southern MN
    Looks like I need to start looking for the torque specs. So just go to https://techinfo.toyota.com/ , create an account, and sign up for a given period of time? Looks like 2 days is $15. I'm assuming most people get the two day and print out/save all they can in that period of time. (y)
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Yup;).
    When I got the $15 subscription, I got our 2010 Prius and the 2017 RX450h completed, then did some spot duty for some other side projects :).
    But get it on a Friday and plan the weekend accordingly (y).
  19. padroo
    2,763
    2,253
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I see a one month subscription there is about $20, so a better deal than techinfo.toyota.com for a month, but a 2 day subscription there is $15:).
    I’d go to the source, but that seems like an option(y).
    farmecologist and padroo like this.
