Suspension Creaks on Speed Bumps and Driveways when applying brakes
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by prevee5, Sep 10, 2022.
  1. prevee5
    prevee5 Member
    121
    Monrovia, California
    As the title says, I’m experiencing creaking sounds coming from the suspension while going slowly over speed bumps and driveway approaches but ONLY when the brakes are applied.
    Anyone experience this? Any fixes?
    Thanks
    2012 Prius v Model 5, no ATP
    130K miles
    51,155
    idk, but have you cleaned the egr circuit?
  3. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    I don't know if you wish to do a DIY repair/ inspection.
    Appling brakes is a weight transfer to the front suspension.
    10 yrs 130K miles could be the rubber suspension components have hardened, cracked, need lube, loosened or failed.
    Further, as you state "while braking", it could be caliper related.
    I could suggest you do one wheel first, in an attempt to find the specific issue.
    Perhaps the easiest, but prudent, way is to remove one rim/ wheel.
    Spray silicon spray onto all the rubber components to lube them.
    Check the condition of the lube on the caliper / pad pins.
    Check the bolt torque on the shock absorber mounts and the caliper.
    You could go further and check all the suspension mounting point bolt torques.
    Reassemble, test, and repeat the other wheels as needed.
    Finding creaks and rattles can take some time.
    Sometimes, even if you are sure the noise is from the front it is actually in the rear.
    That's my two cent comment.
    Good luck.
  4. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Struts come to mind. Egrs don't.
  5. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Does it sound any different when you reverse over a speed bump with brakes applied?
    Most suspension creaks I've chased in older Japanese cars came down to dried-out bushings for the control arms, links and sway bars.
    So far I can't account for why yours would change with brakes added.
    Air_Boss likes this.
  6. Air_Boss
    Air_Boss Senior Member
    4,140
    1,154
    New Yawk
    Braking changes the suspension loading. It's a suspension bushing or fitting.
  7. prevee5
    prevee5 Member
    121
    Thanks for all the tips. Was hoping someone shared the same issue and had a quick fix. I hate looking for “noises”!
    looks like I have a lot of investigating to do.
  8. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    You could rent a set of chassis ears (that's the name of the tool) to make the hunting a bit easier.
    Or just get a few cans of silicone lube and hose down every rubber bushing you see.
  9. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Looking at the bushings may reveal them to be cracked/leaking. Eventually there will be a sound so very likely this problem can be seen.
    REVVL V+ 5G ?
