Suspension making squeaking sounds, what could it be? Video
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bronx99, Mar 17, 2019.
  1. bronx99
    bronx99 New Member
    Irvine, CA
    I plan on taking it to a shop, but just wanted some of your takes so I know what i'm dealing with. I'm guessing it's either the shock/spring, ball joints or bushings. Thanks!
  2. bronx99
    bronx99 New Member
    Irvine, CA
    the weird thing about it as well - is that the sound only happens when i'm coming home from a drive. In the morning when i get in my car, the sound is not there.
    52,807
    how many miles on her?
  4. bronx99
    bronx99 New Member
    Irvine, CA
  5. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    Mine does the same thing. It's the exhaust spring bolts. It only happens after she's warm. Wd-40 should do the trick but I'm to lazy. :LOL::LOL::LOL:
    Plus I like rocking the car, when she's making noise, while looking at my girlfriend with devilish eyes:love::love::love:
    The Critic likes this.
  6. bronx99
    bronx99 New Member
    Irvine, CA
    Where can i find the exhaust spring bolts? any pics?
  7. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    WD-40 on exhaust parts? No, I think it would all burn off during your first drive.
  8. Greenteapri
    330
    388
    Cypress
    They look like this.
    Follow your exhaust piping and spray away.
    Operating temp for wd-40 is up to 300°f.
    #8 Greenteapri, Mar 21, 2019
  9. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    My Prius is making the same sound @ 120K. It's the front sway bar links. Only does it when hot, on the way home from work. I can see the rubber boots cracked and torn allowing the elements into the ball socket. I'm going to change them this weekend. I'll update.
    Raytheeagle likes this.
  10. padroo
    padroo Senior Member
    2,763
    2,253
    When I changed the front struts on my 2008 Prius I installed new sway bar links that I got from Advance Auto. There was a selection from different companies and the one I used had bad reviews because it was noisy and it squeaked right out of the box. I returned it and used another brand but don't remember the brand name, just read the reviews is all I am suggesting.
    Colm01 likes this.
  11. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    20190322_154843.jpg 20190322_160241.jpg Replaced the sway bar end links and the noise is gone! Two trips to and from work with no squeaks!. Here are the photos of the links.
  12. gliderman
    gliderman Active Member
    751
    225
    Front or rear?
    Colm01 likes this.
  13. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    These were the front sway bar links.
    gliderman likes this.
  14. padroo
    2,763
    2,253
    Glad it worked out for you. What brand are the new ones?
    The rod part on my 2008 was round, I see they made some changes on Gen 3.
    Colm01 likes this.
  15. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    The new ones were Toyota. The aftermarket ones were round and made of steel so I steered away from them. I went with the OE aluminum ones.
  16. padroo
    2,763
    2,253
    Generally speaking you can't go wrong with OE equipment especially if the aftermarket maker has no recognizable name.
    Most of the time it comes down to price and availability.
    I have seen local parts stores supplying parts to dealers.
    Colm01 likes this.
