Suspension refresh DIY - how difficult?
Discussion in 'Gen 3 Prius Main Forum' started by redprius10, Sep 24, 2025.
  1. redprius10
    redprius10 Junior Member
    Virginia
    Hi folks.....my 2010 Prius with ~151,000 miles is in need of a suspension refresh (lots of creaks and groans). I consider myself fairly good at repairs/maintenance, but have never done control arms. I've done shocks, tie rods, and other steering components on a Jeep.
    Looks like the rear shocks on the Prius are easy. As for the front and rear control arms and front shocks/springs, can that be done without access to a lift? On a 1-10 scale of difficulty, what am I looking at? I know a bunch of stuff has to come off to access the top of the front shocks, but I've done that before when I replaced the spark plugs.
    Thanks.
  2. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    The rear shocks are fairly easy. You'll have to remove the inside trim to get to the
    top mounting nuts. It will help if you have someone hold the shock while the other
    installs the nuts.
    Replacing the struts is fairly easy also. You will have to remove the wiper assembly and all the
    plastic around the windshield. It's not hard, just clips and bolts.
    You can replace the plugs while you have it off, you are due.
    Oopps, I missread, you already replaced the plugs
  3. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    Get a pedestal type spring compressor that stands on the floor. ReUse your OEM springs. Do not buy quick struts for any reason. Only purchase KYB from rockauto. Do not buy aftermarket. Buy some sway bar links while you're there. Use YouTube videos to self educate
  4. redprius10
    Virginia
    Thanks for the replies...one more quick question. I have the KYB shocks for the rear....they didn't come with the bushings and washers for the top. OK to re-use the OEM ones? Thanks.
  5. ASRDogman
    8,042
    4,075
    Yes, you can use the original nuts. How is the dust cover?
    Don't buy anything from rock auto! They've really gone downhill..... lot's of cheap chinese copy crap.
    And their customer service is about as good as comcast's....
  6. douglasjre
    2,246
    751
    Null, NL
    OEM comes w bushings. Where did u buy from? Also u need shock sox
  7. redprius10
    Virginia
    Bought them from Rock Auto. Installed today...used original bushings and hardware at the top. Also used original boot. Everything went pretty smoothly. Now, on to the front!
  8. redprius10
    Virginia
    Thanks for the reply. Can you elaborate on why not to get the pre-assembled KYB spring and strut? I don't have a spring compressor and, honestly, I'm not comfortable using one. Lastly, what brand sway bar link would you recommend?
  9. ASRDogman
    8,042
    4,075
    Usually, they are generic, not car specific. So they may or may not match your struts.
    You can "rent" a spring compressor from the parts store. As long as your make sure it is
    securely attached to the spring, you're safe.
    You'll likely have to purchase the upper bearing, and probably the cover and bumper stop.
    Which usually will be more than the cost of the quick strut, which is why people buy those.
    Plus it's a lot easier and faster....
