Suspension replacements.
Discussion in 'Gen 2 Prius Main Forum' started by Infamous6i9, Sep 23, 2019.
  1. oil_burner
    oil_burner Active Member
    249
    124
    I replaced mine with aftermarket, but as i warned you before do not do them unless something is wrong. I did mine because I was doing an engine swap and I though they were needed at 270k (they weren't).
    The engine mount has to be undone and the engine has to be jacked up for the bolt to clear the oil pan. Or you could drop the entire subframe cradle like I did, then use an impact to back out the bolts, to find one of them has seized and ripped itself through the stamped steel cradle. Then spend another several hours welding the hole on the cradle back together and praying the alignment isn't f--ked otherwise you might as well drive the car off a cliff. Like I said, don't do it.
  2. oil_burner
    249
    124
    also from reading your post sounds like you need steering rack bushings not new suspension arms.
    SFO and Infamous6i9 like this.
  3. Infamous6i9
    Infamous6i9 Junior Member
    57
    Los Angeles
    That could be the problem. Thank you for your input sir
  4. RoadworrierXL-5
    RoadworrierXL-5 Junior Member
    california
  5. Infamous6i9
    57
    Los Angeles
    Yo you are right. My bushings were fine. And it was the steering rack, there was so much play. Thats where the rattling was from.
    Fostel and SFO like this.
  6. George W
    George W Active Member
    909
    497
    San Antonio
    "The 2nd gen prius doesn't have a "control arm", per se. It has inner and outer tie rods, a steering knuckle, struts and strut ends. "
    "Um it most definitely has a lower control arm. I know because I've replaced them. There is no outer tie rod."
    Great, now I'm further out into the weeds! :cautious:
Loading...
