Suspension/Shock Absorbers in Prius Prime vs 4th gen Prius
Discussion in 'Prime Technical Discussion' started by Rocketboy235, Feb 18, 2023.
  1. Rocketboy235
    Rocketboy235 Junior Member
    34
    24
    MA, USA
    2022 Prius Prime
    Hello,
    I am wondering if anyone here is familiar with the shock absorbers/suspension used in the Prius Prime and also in the 4th gen Prius? Curious if they are different or the same. My parents were driving my Prius Prime and they noted that the shock absorber feel of the ride was not as good as the 4th gen Prius that they normally drive. For myself, I cannot tell but then again I need to do some more testing and pay closer attention.
    Originally I thought since these two cars are similar, the suspension would be similar but maybe that is not the case?
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Check out Off Road Prius. He has videos on Gen 4 Suspension swap with the rear springs. I'd imagine that due to the weight of the extra big battery in the Prime that the Engineers spece'd a higher spring rate in the Primw which might make it feel firmer when empty.
    Rocketboy235 likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Maybe their 4th Gen is a Touring model, with 17-inch wheels. That would make a difference. Also, there's the extra battery weight in the Prime as was mentioned.
    ColoradoCrow likes this.
