suspension/struts/coils/shocks replacement
Discussion in 'Gen 2 Prius Main Forum' started by Senchronize, May 25, 2022.
Tags:
  1. Senchronize
    Senchronize Junior Member
    30
    arizona
    thanks, I'm having a hell of a time disconnecting the swaybar nut and hex combo, I'm afraid to strip the hex hole now...
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    yep. I had trouble myself. I held it with vice grips and finally got it off. Bought new sway bar links. I had to buy from local auto parts for $80. On my wifes car I planned ahead and bought a new set for $40 when I bought the rest of the stuff.
  3. Senchronize
    30
    arizona
    i did buy new ones already, the old ones stripped, i ended up using the breaker bar to loosen it, anyway got one side done. Took from 9am to 1pm lol, now for the other side, hpoefully much faster. I did have to stop and clean out the rust and apply copper antiseize and everything. I had trouble with losening the knuckles nut too, rustlocked pretty hard.
  4. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Sounds like mine. I am lucky to have no rust. The other side will be faster because now you have done one so you know what to expect.The rears are a breeze compared to the fronts I think.
  5. Senchronize
    30
    arizona
    hah only took 1 hour and a half on the other one, definitely easier knowing what to expect now. Took it out for test drive so much better now, my passenger right side use to wobble really hard now it stablizes quickly. torqued everything to spec and will check them again in a couple of days. Thanks for the help, I only doubted doing it myself twice this whole procedure hahahha. swaybar links and the knuckle, both issues fixed with my long breaker bar. I would do this again, good learning experience.
    ColoradoCrow likes this.
  6. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Yup. Good job. And now you can help the next guy. I'm tackling this project again in 2 weeks on my wifes car.
    :p
    SFO and Senchronize like this.
  7. Senchronize
    30
    arizona
    Yup all is good! Do you know what this part is called? (The boot) my passenger side seems to be broken off?
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Can't see if the rubber on the tie rod end is actually broken or cracked, can you slide it back on?
    Additional part(s) source : 2005 TOYOTA PRIUS 1.5L L4 ELECTRIC/GAS Tie Rod End | RockAuto
  9. Senchronize
    30
    arizona
    I'm not sure either, what does that control? lateral suspension? or actual movement?
    Another picture of the passenger side: [​IMG]
    This is the driver's side:
    should i replace it or try to tighten it back? What am I suppose to feel when it is brokeN? Thanks!
