Suspension upgrades worth it for handling?
Discussion in 'Prius v Accessories and Modifications' started by Carpetfuzz, Sep 6, 2025.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    Flex and ductile structures absorb vibrations that cause m metal fatigue which us the result of brittle fracture.
    The bonds between the molecules in the metal alloys are broken and separate.
    All metal structures eventually fail. Some sooner:some later.
    Get the combination between brittle and ductile structures wrong: failure occurs early.
    Get it right; failure occurs much later.
    The Douglas DC-3 is the best example.
    The worst is the RMS Titanic and the Mitsubishi A6M2 Zero.
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Good luck with your upgrades. I'm satisfied with mine.
  3. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Not luck; just good engin engineering.
    Still working great after more than 10+ years.
    Toyota has adopted them for the next ge generations of Prius models.
  4. Air_Boss
    4,259
    1,197
    New Yawk
    More likely the result of TNGA, since 2016 models, and hard to believe add-on chassis braces would improve things.
    Toyota's New Global Architecture (TNGA) significantly reduces chassis flex and twist by increasing torsional rigidity, which leads to improved handling, ride comfort, and stability. By designing more rigid platforms, Toyota can better control body movements and tune suspensions for both comfort and sporty handling.
    Key innovations to reduce chassis flex
    TNGA's increased torsional rigidity is achieved through a combination of manufacturing processes and structural design improvements:
    • High-strength steel and structural adhesives. High-strength steel is strategically placed throughout the chassis to reinforce key areas without significantly increasing weight. It is then combined with structural adhesives, which are used to reinforce joints where spot welding is difficult. This creates a stronger, more continuous bond for increased rigidity.
    • Annular frame structure. The body frame is optimized to create a circular or "annular" structure around the body openings, such as the side doors. This distributes forces more effectively, increasing overall rigidity.
    • Laser screw welding (LSW). LSW allows for more precise, high-speed welds at shorter intervals along the frame than traditional spot welding. This technique creates stronger joins, contributing significantly to a stiffer chassis.
    • Lower center of gravity. All TNGA platforms are designed with a lower center of gravity. This inherently reduces flex by limiting the leverage that cornering and braking forces can exert on the chassis, resulting in less body roll and pitch.
    • Tailor-welded blanks (TNGA-F). For its truck and body-on-frame SUV platforms (TNGA-F), Toyota uses tailor-welded blanks. This process joins multiple steel sheets of varying thickness and strength before they are press-molded, allowing for strength to be concentrated in high-stress areas while keeping overall weight down.
    Benefits of increased torsional rigidity
    Reducing chassis flex and twist through TNGA delivers several performance advantages for Toyota's vehicles:
    • Improved handling. A stiffer chassis provides a more stable and predictable foundation for the suspension. This allows the suspension to work more effectively, leading to improved steering responsiveness, enhanced cornering, and reduced body roll.
    • Enhanced ride quality. While a stiff chassis might sound uncomfortable, it allows engineers to tune the suspension for better ride comfort. By isolating the cabin from road imperfections, the suspension can more effectively absorb bumps and vibrations.
    • Greater stability. The reduced body movement translates to better vehicle stability, especially during high-speed cornering or in demanding driving conditions.
    • Improved safety. A more rigid structure can better manage and absorb crash forces, protecting the cabin and its occupants in the event of a collision.
    • Reduced noise, vibration, and harshness (NVH). A stiffer structure minimizes the points of flex that can create noise and vibration. This results in a quieter and more refined cabin environment.
  5. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    Respects, but you are 25 YO and have a 9 YO Prius V with 142,000 miles on the clock. Based on that info alone I would say no. There are a few mechanical issues coming up to deal with that will cost you...and this money would be better saved for those...or a replacement vehicle that better serves you wants and needs.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    A 2016 v wagon "ricer"? Personally I find the v's handling nimble and precise with a better ride than a hatchback. Not that the ride is great on rough surfaces and there is almost zero sound deadening anywhere. But on the freeway it is stable and able to quickly avoid problems and fit through gaps many bigger vehicles can not.
    When it comes to acceleration and raw performance it already has a lower numerical final drive than the hatchback. As long as your goal is to stay with normal traffic entering the on ramp it is fully capable. But trying to keep up with anything commonly recognized as a "hot hatch" (Civics come to mind) you are in the wrong vehicle. The hybrid engine is intentionally underpowered by the factory with its Atkinson Cycle cam timing and ecu combined with a transaxle which is not controllable by the driver.
    Later Toyota hybrids improved acceleration with dual injection, electric driven variable intake timing, more cubic inches while maintaining mpg and controllable ecvt transaxles. Plus more power added by lithium hybrid batteries and Toyota software to unleash it.The battery size increase in a modern plug-in hybrid can take a 200 hp Atkinson hybrid up to 302 hp with massive acceleration.
    However adding any of the improvements to a gen3 Prius v is next to impossible. You are stuck with port injection, a 1.8L (110 cubic inches) engine, engine control optimized for mpg, no "tunes" available and a transaxle that does its own thing.
    Which is why the gen5 Prius Plug-in or Rav4 Prime are the hot Toyota hybrids. They came from the factory optimized for performance when you want it or mpg the rest of the time.
    #26 rjparker, Sep 8, 2025
  7. Mendel Leisk
    42,343
    Yeah, it'd be a shame to throw a lot of suspension parts at this, then have the engine implode.
    Carpetfuzz likes this.
  8. Carpetfuzz
    Carpetfuzz New Member
    Ohio
    2016 Prius v wagon
    okay okay, I get it! I will make sure my engine doesn't implode FIRST, then ill throw money away upgrading a Prius V :)
    The next closest thing to this hybrid kinda-station-wagon is a Polestar engineered volvo v60, so I have a long ways to go money-wise before I reach my "replace the car" threshold.
  9. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Shocks are worn out. Get new OEM KYB from RockAuto
  10. douglasjre
    2,250
    751
    Null, NL
    Polestar is Chinese crap with a Volvo name badge
    Georgina Rudkus likes this.
  11. douglasjre
    2,250
    751
    Null, NL
    Byw Volvo doesn't stand behind its garbage. Look up Volvo Penta outdrive composite or any other search words you want. The whole boating community knows darn well to avoid anything Volvo. So does the trucking community
  12. Hayslayer
    Hayslayer Active Member
    534
    325
    IMHO, it'd be a shame to throw anything, and I mean anything, at it that isn't the minimum required for safe upkeep. The car isn't meant to be a performance car. It will never be a performance car. Money spent trying to get it be one is money wasted.
  13. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Better handling is always an asset.
    Of course you'll never get those handling dollars back upon resale.
    So the question is what type of better handling?
    Corner holding, braking, or slalom.
    Then street function vs. road race course.
    I would maintain my V street-ablity.
    No lowering.
    But, "stickier" tires first.
    Not sure if brake pads alone will bring a benefit, but rotors and pads will bring greater fade resistance.
    Cross braces... I would buy them all.
    Sway bars, those depend on what you "feel" or need... for example, trying to reduce front corner dive when entering a corner.
    Shocks, just keep them new.
    Compression and rebound adjustment shocks get expensive and again, I would not lower for street functionality.
    Good luck, and some say driving a slow car (yeah a Prius V :) ) fast is the most fun.
  14. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Again, I found the bracing to be the best investment.
    They alone gave me the exact handling result I needed. It was the gest $300 that I spent,
    I needed to go no further.
  15. Joele3
    Joele3 Active Member
    137
    205
    Bay Area
    Ive got the Cusco front strut bar and TRD rear sway bar. Ive been eyeing that mid brace as my next upgrade. Also replaced all struts and shocks with Tein Enduro Pro. The pro are the adjustable dampening version. With Teins it rides as if it were lowered without being lowered scraping all over the place. I was really surprised. I recently installed the same brand on my uncles regular prius 2010. Hes extremely happy. Everyone who rides in my V are impressed how it handles. I drive it like like a roadster.
    Carpetfuzz and Georgina Rudkus like this.
  16. Weirderal
    Weirderal Junior Member
    57
    Pennsylvania, United States
    I actually got a lift in the form of the front & rear heavy-duty springs from Prius Offroad. Just a 1.5" lift, but still. I scraped a large speed bump between the front and rear tires once before getting the lift, and it hasn't happened since.
    Also, the springs are orange.
    Unfortunately I'm the last person to ask about handling/dynamics, because I've been driving my 2012 v since 2019, and before that I drove a '97 Ford Econoline conversion van for 7 years. So compared to that, my v was already a race car (even if it's about half a second slower to 60...)
    Air_Boss likes this.
