Swansea Cardiff Area
Discussion in 'Generation 1 Prius Discussion' started by Leslie watson, Mar 2, 2019.
  1. Leslie watson
    Leslie watson New Member
    Uk
    2001 Prius
    ----UK----
    hi.
    We have a 2001 Prius we cannot start so need help please.
    Car was laid up for 18 months so won't start.
    Leslie
  2. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    Car should be towed to shop that can recharge the HV batteries, probably discharged or corroded.
    Prius must be run at least every 2 weeks for 5 minutes over 1000rpm to stay in operating condition IMHO.
  3. orenji
    orenji Senior Member
    5,887
    3,490
    It’s an old car and an old battery. Only the dealer or good Prius shop will be able to advise you. But it could just be the 12 volt battery is dead.
  4. Leslie watson
    Uk
    2001 Prius
    ----UK----
    Hi.
    Can the HV batteries be charged in the car or do they have to be removed.
    Leslie
  5. Leslie watson
    Uk
    2001 Prius
    ----UK----
    Can the gas engine be started with HV battery flat.
    Is there a cheat to start the gas engine when HV is dead.
    If we can start the gas engine it may help us sort the HV battery out.
  6. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    The HV battery starts the car as it's the generator motor that is used to achieve this. So if your HV battery is flat, no start.
    Go through the simple stuff first. Check the 12V battery then you know where you stand. It's also a good idea to get Techstream and once you have a good 12V supply, you can check the HV battery modules.
  7. Nelsonprius
    72
    Nelson, BC Canada
    2001 Prius
    I
    Yes the HV battery can be charged in the car, but first make sure the 12V battery is over 12.1v
