swap left-right seats
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 4est, Mar 24, 2017.
  1. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Can I swap left-right seats in my 2013 Prius?
    The driver seat is quite worn in a spot (on the left side back support)
    Seats usually wear more where you rub against them when you enter/exit the car, so swapping left-right sounds logical
    But I wonder how difficult (if possible) it would be....
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    I don't believe you can swap seats, the recliner is on the sides and the seat wiring plug will be different on each side. My Prius 4 driver side seat is electronically controlled when setting the seat positions, my passenger seat recliner are all manually controlled.
    #2 NutzAboutBolts, Mar 24, 2017
    Raytheeagle likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Seat covers...
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I hate seat covers!!
    iPhone ?
  5. xliderider
    8,140
    3,280
    Honolulu, HI
    m.wynn likes this.
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Aren't there airbag systems on the exterior sides of the seats also?
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Here's the airbag system on my 2013 PiP. Yours may be a little different. Also, note the seat adjustment controls as previously mentioned. And the mounting bolt pattern may not be symmetrical.
  8. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    So airbag no 3 is a problem
  9. jerrymildred
    11,517
    14,171
    Tampa, FL
    Among other things, yes. Check your owner's manual. If you get the pdf version on line, you can just search for "air bag." That's what I did.
    But you also probably can't get to the seat controls if they're jammed against the center console.
  10. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I was thinking of only changing the upper part
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    Ah! That may be different. Not sure if that's symmetrical. But you'd still have the air bag issue if yours are like mine.
