Swapped out taillight assembly and still have issues.
Discussion in 'Prius c Main Forum' started by thefyn, Jun 21, 2025.
  1. thefyn
    thefyn Junior Member
    33
    Treasure Coast
    I swapped the whole rear right light assembly and it worked for a day. Then the tail light stopped working. Then all in that assembly stopped working.
    The previous one that broke was filled with water then the back fell off. Are there any fuses etc that I can swap out to see if it fixes it? Any trouble shooting advice would be great.
    2012 Prius C 3
  2. John in Vermont
    John in Vermont Junior Member
    50
    22
    Rochester, Vermont
    2018 Prius c
    I would look at the plug between the light and the harness first. If it is corroded or loose that would cause your problems.
  3. thefyn
    33
    Treasure Coast
    I didn't see a plug that separated the pigtail to the rear light when I removed it. Only the bulb attachments pigtail. Is it located elsewhere? The fuse tested OK for continuity. All the bulbs could also be blown so is there a set that are the right size for each of the rear assembly on amazon? Thanks
