Swapping HV Battery Electronics
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brandon.S, Dec 20, 2018.
  1. Brandon.S
    Brandon.S New Member
    CT
    Hello all!
    Just bought an 05 Prius and a new battery from the dealership (after some serious effort, got it for $1640 too).
    Does anyone have a write up for what goes into swapping the electronics from the core battery to the new battery?
    Thanks in advance!
    SFO likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    The main thing you’ll be doing is assembling the modules and using the new hardware that came with the battery. The toughest part is packing it so you get the core charge back.
    Good luck and keep us posted (y).
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Sounds like an opportunity for you to contribute to the community and share how it is done.
    Basically it is removing the connecting screws, nuts and connectors, black hoses, white rectangular plastic clip, etc.
    Then swap them onto the new core.
    Be sure to use the 6 new nuts. Noting that the contactor nuts are different than the battery post nuts. Use the new foam baffles. One has a larger opening than the other. That one goes on the wireframe side of the pack.
    Double check that you didn't accidentally knock the temp sensor on the end of the pack when handling it. Ot should be clipped tight to the underside of the module.
    Be sure to properly tighten the HV battery connections with an inch-pound torque wrench. DO NOT GUESS ON TIGHTNESS. Do it right. You saved on the pack cost, so you can certainly rent or buy the proper tool. Undertoqued can lead to arcing and a fire. Overtorquing can lead to broken parts.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Its unfortunate given the thousands of posts about the hybrid battery rebuild there's not a special and specific HYBRID BATTERY FORUM.
    Frustrating as all hybrid battery posts are spread out among the different G2 forums. Lots of really good info but its just a mess.
    Best bet is to use the blue search forums button up top and search the G2 forum for:
    HYBRID BATTERY
    You will find gold you just have to dig a little. Settle in for some reading and printing.
