Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. Jacob Bonner
    Jacob Bonner Member
    86
    44
    United States
    Camshaft position sensor
    #261 Jacob Bonner, Feb 17, 2020
  2. Mendel Leisk
    41,428
    Better?
    Jacob Bonner likes this.
  3. Jacob Bonner
    Jacob Bonner Member
    86
    44
    United States
    Latest update: I tested all three wires on the camshaft sensor connector. For these tests, I punched the start button twice without my food on the gas pedal, to turn on car without starting engine.
    Tested the constant wire (black), and the reading is anywhere from 5 to 5.3 volts.
    Tested the continuity on the ground wire (white), and I do have continuity.
    Back probed the signal wire (red) while the connector was connected to the sensor, I got 1.22 ohms of resistance.
    While back probing the signal wire (red) I also tested the voltage, and got no signal (though I'm not 100% sure if I'm suppose to be getting signal at this point).
    While back probing the signal wire, am I suppose to ground the tester to the engine or ground to the ground wire in the connector?
  4. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Not sure how much help I can offer, as you're far beyond anything I've attempted with a gen3/4. But I will take the lead (without pointing fingers, maybe some of the OG swappers will step up?) and work through this step by step, hopefully we you can figure this out with a little help.
    Just to clarify, there are no other DTCs currently showing (yes, you aren't using Techstream.. yet)
    Two button presses without a foot on the gas brake pedal, would be IG(nition)-ON
    The workup for DTC P0343 starts at page 2402 (of 7595) in the gen3 manual (linked above, loads faster if saved locally. Wish we collectively had a reference copy of the gen4 manual), now skip down to page 2407, hold the sensor wire with the clip end at 12 o'clock, probe pin 3 [ D18-3 (VC) ] on the right side (same black wire?) and test to body ground, the manual says it should read between 4.5v and 5.0v for 'standard voltage'. If you're reading 5.1v or above, then this could be the problem and we'll you'll need to move on to the next step in the workup : NG > CHECK HARNESS AND CONNECTOR (CAMSHAFT POSITION SENSOR - ECM)
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Having reread the thread, I think the answer is to remove the timing cover and reset the cam/crank relationship. The “clunk clunk” sounds were likely the chain jumping over the camshaft gear.
  6. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Wouldn't the timing cover, cam, and chain tensioner be left undisturbed during the swap?
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Yes, but the tensioner is held in place by two things. A spring loaded tang and engine oil pressure. If the tang is worn/broken, then the lack of oil pressure against it would allow slack in the chain.
    SFO likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Is there a way to prevent such a thing from happening during future swaps?
    How long could a spring loaded tang be expected to last given normal wear, or when using a dealer maintenance schedule?
    If known, how many miles might you have on that used gen4 replacement engine?
  9. Mendel Leisk
    41,428
  10. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Even though my engine was around 10k miles, I put a new OE tensioner on when I did my swap.
  11. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Thanks @Ragingfit for putting up those videos
    Finally finishing up on my install using:
    Gen 4 EGR
    Gen 4 Intake Manifold
    Gen 3 Exhaust Header
    Gen 3 modified wiring harness
    Gen 3 Intake Air Box
    No engine codes or knocking noise when starting up.
    Avg 50 mpg
    iPhone ?
  12. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    No - No - No
    Did not work! Followed another Member that did this and caused an engine code (Insufficient EGR flow)
    No need to re-pin
    iPhone ?
    Ragingfit, SFO and Mendel Leisk like this.
  13. Mendel Leisk
    41,428
    Ah, so leave the pins as-is?
    The two pics you posted above: the first looks like a real spaghetti fest. Is that the before, and second is after you tidied up?
    That's a head-spinning mass of wiring. :eek:
    I really think you should run that into a dealership for an oil change, some excuse to have them pop the hood... :sneaky:
  14. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Correct EGR circuit did not open completely causing the car to have a slight hesitation while accelerating
    iPhone ?
    SFO likes this.
  15. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    All cleaned up
    iPhone ?
  16. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    What part of the wiring did you modify pls?
  17. Jacob Bonner
    Jacob Bonner Member
    86
    44
    United States
    There are 47k miles on the Gen 4 engine.
    Today I opened up the valve cover to see if I could look at the timing chain. I didn't go to the trouble of removing the side panel, but the two timing marks on the top line up. What are the odds that the two on top line up and the bottom doesn't? Others here may have more experience with the timing than I do. Wish I had checked on this when I had the engine out...
    94701496_3800718040000158_7877836831163678720_n.jpg 94522253_711125766326957_4805799010990292992_n.jpg
  18. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    Zero chance.
  19. tacopyro
    tacopyro Member
    86
    43
    Los Angeles
    if you took off the harmonic balancer, you can peek through to see if the chain yellow mark is at the dot.
    CTTO.
    Jacob Bonner, SFO and cnc97 like this.
  20. Jacob Bonner
    Jacob Bonner Member
    86
    44
    United States
    Today I managed to get my OBDLink MX+ code reader working. Apparently a software update had occurred months ago, and I had to re-register the device. OBDLink MX+ can detect hybrid codes that others can't (including the other code reader I had been using). So, armed with the OBDLink I was able to detect some additional codes.
    Confirmed:
    P0343 - Camshaft Position Sensor "A" Circuit High Input (Bank 1 or Single Sensor) which I had already
    C1259 - HV Control System Regenerative Malfunction
    C1310 - HV System Malfunction
    P0A0F - Engine Failed to Start
    Pending:
    Meanwhile, I only have 20.3% Hybrid Battery power left (showing as 1 bar on the console). I wouldn't have thought that this would be the underlying problem though because the engine will start - it just roughly force-stops after several seconds. It's not as if the engine won't start at all.
    As for the 12V battery, I tried swapping it out with my father's 12V from his Prius (fully charged) and that did not clear up my problem either. I know the 12V is usually under scrutiny with many of these codes.
    Another thought: perhaps the gas is too old? The car has been sitting for 5 months now..
    #280 Jacob Bonner, Apr 27, 2020
