Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. Mendel Leisk
    41,427
    Maybe air pockets part of it?
    Memory like a sieve: were we just talking about @Ragingfit 's trick, to unbolt the reservoir and raise as high as possible?
    Ragingfit likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Amazing progress, now I feel like I'm missing out on all the fun.
    Be sure to read this @Jacob Bonner posting [bold is mine] :
  3. Joe Legan
    Joe Legan Junior Member
    16
    45
    TN
    So I ended up ordering a water pump from Toyota, based of what @Jacob Bonner has gone through. It will be here Wednesday and hopefully things go smooth from there.
    michaud85, SFO and Mendel Leisk like this.
  4. michaud85
    michaud85 Member
    61
    47
    Salem
    It's great to see other people doing these swaps haha. After a few months, and some experiments with 4th gen EGR I got it running well but not perfect with a quick modification. I added a valve spring cap from an old 7.3 diesel to restrict the flow from EGR into manifold. The thought here is to minimize the effects and contributions the new EGR has on engine performance.
    I swapped in KN filter for slightly higher flow on intake side to make up for any lost EGR air. I played with the size of the opening a little but the results were so good with both hole sizes, 5/16” & 3/8”, I decided I didn't want to mess it up (I only had 1 retainer cap so I can't make the hole smaller again). My gf drove the car for a few weeks and she isn't complaining. Car works almost perfect, no CEL, but mpgs are a little low and it has some funny pre experiment EGR symptoms occasionally. I'll be honest I just don't want to work on the car anymore and I'm well over the gremlins of 4th gen EGR.
    I bought 3rd gen EgR last week that I will install into the vehicle. Ill span it any way the pipes will line up again.
    I decided to go back to 3rd gen because this a 100% perfect and proven solution. I only tried to make 4th gen work for so long because I scrapped 3rd gen EGR after the swap thinking I could fix the issues due to some of the claims on here.
    The bottom line is, aside from EGR, the rest of these 2 engines and components combine with ecu to work the exact same. However 4th gen EGR and 3rd gen are built and designed to perform inherently different in many ways. Because of this, without a well tested and engineered solution you simply can't know if you are maximizing vehicle potential or if any symptoms you have in the future are a result of the informal modification.
    For the people wanting to go 4th gen EGR I say, why? the swap already requires significant modification. In the case of the 4th gen EGR there is simply no benefit to running it, only potential complications. The juice is not worth the squeeze. Considering what has been done so far, and the vast difference between EGR generations, 3rd gen ecu deserves a 3rd gen EGR IMO.
    #424 michaud85, May 31, 2020
  5. ChapmanF
    18,160
    Most of this post makes sense, but I am doubtful that this point would be doing much for you, for a couple reasons: (a) whatever you do air-filter-wise, it is upstream of the mass-airflow sensor, and that's what the ECM is relying on for flow metering, and (b) our best guess is that by adding your EGR restriction, you are correcting too much flow to be closer to the expected amount ... therefore nothing to make up for.
  6. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Glad you were able to solve some of your Gremlins from your Gen 4 / Gen 3 Frankenstein build!
    iPhone ?
  7. michaud85
    michaud85 Member
    61
    47
    Salem
    Frankenstein!
  8. Joe Legan
    16
    45
    TN
    Still having problems getting the air out of the system, I had to replace the water pump and thermostat because they were bad.
  9. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    After a few weeks, if it doesn't get better, cut the jiggle pin on the thermostat to keep hot coolant flowing through the thermostat housing.
    That should be the end of that.
  10. ChapmanF
    18,160
    I'm glad my parents were more softhearted.
  11. Joe Legan
    16
    45
    TN
    Still overheating not sure what else to do. Pulled a vacuum on the cooling system and the refilled it still overheating, flushed the system and the same result. When I use a temperature gun on the hoses, thermostat and tempo sensor housing it reads 20 degrees cooler. Any suggestions?
  12. Ragingfit
    189
    249
    Aurora, IL
    cut the jiggle pin
  13. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Question?
    At anytime before the swap, did you use headgasket sealant that you would poor into the coolant reservoir?
  14. Mendel Leisk
    41,427
    Which kinda reminds me: form-in-place gasket got into coolant passage? Hopefully not, that would be a sand-pounder.
    RightOnTime likes this.
  15. Joe Legan
    16
    45
    TN
    Ok will try that tonight, but I am pretty sure the thermostat is opening
  16. Joe Legan
    16
    45
    TN
    I did not, however the previous owner may have. I bought the car and literally a week late all this happened.
  17. Joe Legan
    16
    45
    TN
    Looks like the cutting the jiggle pin and drilling a few extra holes worked!!! Drove it around for a while and didn’t get over 194 degrees!!!!!
    Montgomery, Ragingfit and SFO like this.
  18. Mendel Leisk
    41,427
    What is this jiggle pin? (n)
    It allows thermostat to open a bit sooner?
    Ragingfit and Raytheeagle like this.
  19. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Interesting. Is the coolant in the reservoir bright pink? Or a darkish color?
    iPhone ?
  20. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Sounds like a technical term:cool:.
    Definitely the type of term not found in the repair manual:whistle:.
    Maybe @Ragingfit or @Joe Legan will help us with location and description :).
    Pics are best(y).
