Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Check the service plug. In, down, over.
    Raytheeagle and Mendel Leisk like this.
  2. justdog
    justdog Junior Member
    62
    Ca
    That was it. Thanks. Started rough for about 3 seconds then turned off. Tried again and smoothed out for about 5 seconds then turned off. Now it won't start at all
  3. justdog
    62
    Ca
    Now it's telling me check hybrid system again. Won't even let me in main mode. Damn
  4. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    Did the car get the stop leak treatment?
  5. justdog
    62
    Ca
    Okay jump started battery. Put it in maintenance mode it starts up and sounds smooth for about three to four seconds and then stops instantly
  6. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Check for codes. Check electrical plug in on TB, check map sensor plug.
  7. justdog
    62
    Ca
    I think battery is low. I put it in maintenance mode and won't do anything when I push button. Do hybrid batteries have anything to do with car starting in maintenance mode?
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    The hv battery has everything to do with actually starting the gas engine. The system uses one of its motor generators to spin the engine.
  9. justdog
    62
    Ca
    Damn. You know your stuff!! Thanks. Throttle body plug loose. Purring pretty good! Throttle body plug was on but not clipped all the way in!!
  10. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Things I missed when I did my engine swap. Been there, done that.
  11. Mendel Leisk
    41,473
    (y)(y)(y)
  12. justdog
    62
    Ca
    Thanks. I thought I read that somewhere. Second guess myself when frustrated. Haha. Thanks
  13. PNP3
    PNP3 Junior Member
    28
    Philly
    No
  14. justdog
    62
    Ca
    Job completed!! Kind of dirty from sitting. Can I lightly pressure wash Prius engine? Image%20(2).jpeg
  15. justdog
    62
    Ca
    Spoke too soon,!
    Two problems. Hose from blocked twisted and kinked about half closed. Egr sitting right on top of temp sensor putting pressure on wires or my solder job sucked!! Gonna have to remove a bunch of stuff just to fix hose. Damn!! Should have used galvanized pipe instead of coupler from 16 motor! If I have to resolder I'm gonna really be screwed! Image%20(5).jpeg Image%20(6).jpeg Image%20(7).jpeg
  16. Mendel Leisk
    41,473
    You'll prevail!
    Don't pressure wash after, don't tempt fate!
  17. justdog
    62
    Ca
    Thanks. Got another problem. I left it running in driveway and now got this again! CHECKHYBRID SYSYEM. STOP VEHICLE IN A SAFE PLACE. Now won't start, even in maintenance mode. I don't get it
  18. justdog
    62
    Ca
    It's strange because there have been times at work where I would forget to turn it off cause it was EV mode and it would be fine 4 hrs later!Hahaa
    #538 justdog, Dec 1, 2020
  19. justdog
    62
    Ca
    Could the 12 v battery be dead. If I change it will it run car enough to charge hybrid?
  20. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    If the 12v was dead, you wouldn’t get the message on the dash. Pull the codes and find out what it has stored.
    PNP3 likes this.
