Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. Ultimate_Combination
    65
    48
    Durham, NC
    [QUOTE="Mendel Leisk, post: 3117124, member: 69191]
    Did you have any trouble removing the existing flywheel bolts, assuming they have something like Red Loctite? I've heard it takes torching the bolts to loosen to soften that stuff enough.[/QUOTE]
    I used a breaker bar on that 14mm multi-pointed socket to gently loosen those bolts myself
  2. Topshelf147
    Topshelf147 Junior Member
    27
    24
    PA
    Lol. Italian tune-up is scarily accurate. :). Yeah, 32 pages deep I can imagine it's hard to keep up.
    I actually have a Ryobi 18v impact wrench that blasted them off in seconds. Without a high torque tool like that, I can imagine it would be a major pita as they are locked in there darn good.
    RightOnTime and Mendel Leisk like this.
  3. Mendel Leisk
    41,442
    I wonder if there's some size of double hex socket (or triple square?) for the flywheel bolts, sim to head bolts. For the latter there IS a double hex spec'd in repair manual, but as far as I can see nothing mentioned for the flywheel bolts.
  4. Mendel Leisk
    41,442
    Heat application to those bolts might be prudent; could you possible take the bolt head off (and then you're REALLY screwed)? I know torching is recommended for Red Loctite.
  5. LeviK
    LeviK Junior Member
    Raymore, Mo
    I’ll do that probably tomorrow and see what is going on.
    RightOnTime likes this.
  6. Mendel Leisk
    41,442
  7. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    Most likely caused by a malfunctioning EGR. Sometimes, unplugging the EGR will make it run well.
    I must admit your car sounded terrible. I was speachless.
    - Fix That Prius !!!
  8. Topshelf147
    27
    24
    PA
    @Ragingfit That's actually my thought as well. My EGR was effectively 100% blocked when I disassembled the original engine. Had I not already had a replacement gen4 sitting in the garage, I would have just swapped out the EGR first as I'm pretty sure that was actually the cause of my issues, not a blown head gasket as I assumed. But it's done now and I'm happy to have a more reliable engine installed as I plan on keeping this car until it falls apart. :)
  9. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Comparisons between Gen 4 vs Gen 3 water pumps
    Gen 4
    Gen 3
    My theory is that the Gen 4 water pump runs much cooler and is less prone to have issues versus its counterpart
    Burna J likes this.
  10. Ultimate_Combination
    65
    48
    Durham, NC
    Gotta thank @Ragingfit with his FixThatPrius videos! These videos are what I've used to get this baby running!
    2 months later, last night I finished, said a prayer and started her up- she fired right up! Sounded like a diesel for a minute but smooth since! No CELs!
    While bleeding the coolant, I noticed a small leak under the car under the EGR area..I looked all around and couldn't exactly find where it came from, so I am hoping it's a trailing leak along the bottom from the reservoir area. I'll investigate more later after my shift, but I'm relieved the new engine started :)
    https://photos.app.goo.gl/mUMkLrZyietkZ7eQ9
    #650 Ultimate_Combination, Feb 16, 2021
    SFO, Ragingfit and Mendel Leisk like this.
  11. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    Im doing the swap on the my gen 3 with the Gen 4 motor Im a bit confused im going to use all the gen three parts except on confused on how to connect the cooling system as the 3 has a straight pipe and the four has an angle gooseneck. Can anyone point me in the right direction?
    Ragingfit likes this.
  12. Mendel Leisk
    41,442
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
  13. johnnychimpo
    514
    112
    Monterey
    I dont have your skill so what will I need to get my gen 4 engine to work in my gen 3 prius not V
    Ragingfit and RightOnTime like this.
  14. Ultimate_Combination
    65
    48
    Durham, NC
    Ragingfit's yt series pretty much covers the whole swap- take some time to watch them and I am sure your answers will be covered :)
    *hint= Parts 11, 12 and 13 cover the 8 inch galvanized pipe and tee-connector to add another coolant hose to the throttle body ( I took notes LOL)
    #654 Ultimate_Combination, Mar 3, 2021
  15. johnnychimpo
    514
    112
    Monterey
    I have the part with the sensor does that mean I need more parts?
  16. johnnychimpo
    514
    112
    Monterey
    anyone know what that grey sensor is? I hope not another thermostat. Anyone see this before?
  17. Mendel Leisk
    41,442
    Watch...the...videos. I’ve a vague recollection there’s some sensor just along for the ride, but yeah.
  18. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I believe the Gen 4 has 3x coolant sensor, the Gen 3 just uses 2.
  19. johnnychimpo
    514
    112
    Monterey
    yea cause I see it in the video on the goose neck but the video does not have one where mine does its freaking me out! lol
  20. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The Gen 4 also has an oil level sensor that will not get plugged in either.
