Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    Still looking at the codes but the pump does fit. I dont have the manual.
  2. ChapmanF
    18,180
  3. johnnychimpo
    514
    112
    Monterey
    Ok put in the old good pump with bad impeller and error went went away only one was the 261B range/performance. I know this is due to the bad impeller but I call it's wiring good just bad new pump would you concur?
    #823 johnnychimpo, Mar 21, 2021
  4. ChapmanF
    18,180
    Was the old good broken-impeller pump the Gen 3 part number? Is the new pump the Gen 3 or Gen 4 number?
  5. johnnychimpo
    514
    112
    Monterey
    Let me check? but I dont think so as they are slightly diffrent.
  6. johnnychimpo
    514
    112
    Monterey
    Gen 4 pump is 2048K104058 and gen 3 is 10A302077 this is the only number I found on top of both pumps. I think my new newer pump that I get tomorrow will fix this (as it should). THis will buy me time on the evap leak. I also have an EGR coming and I think that will fix that issue. the last one being the evap leak is not super crucial and I can read up on how to address this issue.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,142
    6,304
    Texas Hill Country
    If it were me, I would use a new gen3 pump made for a 2010 Prius. Basically because you have ecus, programming and wiring designed for a 2010 gen3.
  8. johnnychimpo
    514
    112
    Monterey
    I was thinking the same thing today the engine is not relevant but the pump is to the ECU as it expects a gen 3 pump and maybe is why ECU is not happy about the pump response. That being said Can I use the gent three pump? As I recall raging fit had issues with gen3 pump in gen 4
  9. Ultimate_Combination
    65
    48
    Durham, NC
    Last night I swapped over to another new Gen4 waterpump and bled the system last nite.
    Took her on a drive this morning and I was excited that the temps seemed well in light traffic and sitting in Drive Thru.
    On my way back to the house I pushed the car past 70mph and watched the temps rise past 230F, hitting near 240F (no temp light) but lightened up a bit before I got home and she came back down.
    Slowly parker her in the garage and jumped out and listened to the new waterpump and its making a loud whirring noise at around over 200F, just like the other one with ~250 miles on it...so I guess these waterpumps sound horrid while they work...
    I give up and I think I will let my mechanic look at this- I've already discussed this swap and its issues over the last couple of times I've seen him in the last 2 weeks.
    ...reading this above, I guess I should scour these posts to see exactly what the issues a Gen3 WP on a Gen4 engine are, especially on Gen3 engine harness and ECU.
    oh and still no pending or active CEL's
    #829 Ultimate_Combination, Mar 22, 2021
  10. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Your cooling fan isn’t working. I get a cooling fan at 203 degrees of coolant temp. Check the fan and it’s relays.
  11. Ultimate_Combination
    65
    48
    Durham, NC
    I can see (and hear) the first fan start out after 200F and the second fan kicks in after while I bleed the system in Maint Mode.
  12. johnnychimpo
    514
    112
    Monterey
    what pump you got in there gen4 or 3? The overheating issue prior to my pump going out was resolved by putting car on ramps and filling it from the top off the EGR cooler in my opinion eliminating air bubbles. I then ran the car in maintenance mode with tank raised high with bungie cords. My current issue is due to a likely off brand pump. I am now sourcing an OEM from the dealer.
  13. Ultimate_Combination
    65
    48
    Durham, NC
    the gen4 engine came with many parts removed, including the waterpump.
    I ordered a new Gen4 off of a dealership in Boston, ran that for around 200 miles.
    I then ordered another Gen4 from my local dealer.
    I used the AIRLIFT system to pull and hold a vacuum to test for leaks, then filled it using the vacuum to pull in the coolant back to the system- while with the vehicle jacked up in the front and bungeed coolant tank and fiddling with the Air Bleed valve.
    I am at the point now where I'll let someone else look at it as I've wasted wayyy too much time on this thing already.
  14. johnnychimpo
    514
    112
    Monterey
    I did not know there is an air bleed. Where is that?
  15. johnnychimpo
    514
    112
    Monterey
    So no codes? Are you reading in c or f?
  16. johnnychimpo
    514
    112
    Monterey
    Mine shuts down at 217
  17. Ultimate_Combination
    65
    48
    Durham, NC
    see the white knob on the top of that coolant hose on the EGR?
    and yes, F
  18. johnnychimpo
    514
    112
    Monterey
    Wow I had seen that but did not know what it was lol
  19. ChapmanF
    18,180
    At some year in the Gen 3s, that stopped being there.
  20. Mendel Leisk
    41,440
    2012 I think. You could just pull off a topmost hose, achieve the same function?
