Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    The engine looks right how much are they asking for it and what did you pay for the Prius
    Ragingfit and Mendel Leisk like this.
  2. seeker311
    seeker311 Junior Member
    43
    17
    Austin, TX
    I paid 2600.00. That includes $300 for a hybrid battery from a car with 100k miles. It was a package deal. I paid 1730 for engine. That included 131 for sales tax from CA. All more than what I wanted to pay, but the body and interior are in great condition for a 2012. Just worried about the tranny failing, but I guess I can swap that if it fails.
  3. johnnychimpo
    514
    112
    Monterey
    Great the interior is very important if you plan to keep it. not bad I paid 1400 engine delivered by accident if you can believe that.
    TIps buy the long needle nose for coolant clamps and LED light from harbor freight also change the oil for the trans while you have the engine out.
    also buy two oil change containers one for oil one for coolant as you may need to do it a couple of times trust me. Also extend the coolant temp wire while the engine is out trust me. also grind off anything needed while engine is on hoist again trust me .
    #863 johnnychimpo, Jun 1, 2021
    Ragingfit likes this.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The actual risk of trans failure is low. Not zero, but it’s more likely that an accident will take your Prius from you, based on the number of miles reported driven by all of the Gen 3 owners worldwide.
    seeker311 and Ragingfit like this.
  5. johnnychimpo
    514
    112
    Monterey
    Based on worldwide statistics what is the average mileage when the trans fails.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I have been on this chat board for three years, since I bought my Prius. I have only read of four failures. One of them was a snapped input shaft when the damper came apart. The others still operated, but they were noisy. Unless someone else remembers one that I don’t.
  7. Mendel Leisk
    41,431
    Yeah the transaxle failures often the head gasket leaking and subsequent hydrolock, playing havoc with the flywheel/damper twix engine and transaxle.
  8. seeker311
    43
    17
    Austin, TX
    Well if there are minimal possibilities of trans failures, I think we've got a tank here. Engine should be shipping from CA to TX today. Will be pulling old motor and stripping it down this week.
  9. johnnychimpo
    514
    112
    Monterey
    And how many damper failures and are there warning signs? Is my engine swap I noticed the transition between the downshifting and upshifting based on the mg1 and mg2 now that could be strictly from the new engine providing more torque am I wrong or has anybody else noticed a difference when they swap their engine and the way they can feel the power shift between the transmission and the engine
  10. Mendel Leisk
    41,431
    I think when you hear that slamming during cold start, that’s the “buck stopping”, at the damper?
  11. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Mine has a slightly sloppy rear engine mount. I’m just too lazy to put the work into changing it at this time.
  12. johnnychimpo
    514
    112
    Monterey
    Any update??
  13. seeker311
    43
    17
    Austin, TX
    Hi all. 98% done with swap. As stated, the coolant lines are the most confusing part and that's where I need clarification. I have @Ragingfit coolant diagram, thank you, but there is a discrepancy which I don't understand. It is the hose that goes to the thermostat. Does it go to the egr or the heater core? If it goes to the egr, then the hard line isn't even used. Any prompt help is highly appreciated as I am right in the middle of this operation. Also, my junction piece that mounts to the engine has a plastic piece that comes off the back with a sensor. Any insight on that?
  14. seeker311
    43
    17
    Austin, TX
    Sorry, just saw this. Engine installed.. Working on coolant lines. Need to extend the thermostat wire and disconnect the fuel line. Almost there. Lots of small issues. Like the vacuum switch needed to be rotated 180 degrees. I cut off the mounts for the 3rd gen egr cooler. The raging fit vids had some differences that I didn't understand, or that weren't relevant to my engine. Almost there. Will report full list of mods with pics once up and running.
  15. seeker311
    43
    17
    Austin, TX
    Montgomery likes this.
  16. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    The coolant line to the thermostat goes from the bottom, front of the old EGR cooler to the thermostat housing.
    - Fix That Prius !!!
    #876 Ragingfit, Jun 23, 2021
    seeker311 likes this.
  17. seeker311
    43
    17
    Austin, TX
    Awesome! Thank you so much. That's what I ended up doing. Going to fill up the fluids today and fire her up. So if that's the case, then the hard line that is on the 4th gen motor that used to connect to the tstat is not used and can be removed?
    Thanks again!
  18. johnnychimpo
    514
    112
    Monterey
  19. johnnychimpo
    514
    112
    Monterey
  20. seeker311
    43
    17
    Austin, TX
    Nice pics! Thanks! It looks like I'm connected correctly. Still looking for verification the hard line is not used. I know it's not from what the diagrams show, but I'm just looking for clarification. If not used, why no discussion of removing it. I'm starting to wonder if the 2016 uses it and that's what goes to the tstat, but then what would route to lower egr pipe as ragingfit states. Also, I think I have a 2017 engine. It uses a metal oil filter, vs the 2016 which uses a cartridge.
