Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Accessories and Modifications' started by Tideland Prius, Sep 28, 2018.
  1. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I ordered some M5 0.8 x 16mm stainless cap screws to replace the Philips screws. Hard to get in at a straight angle on one of the screws, worried that I'll damage it eventually.
  2. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    Our Shop sourced out a 2017 JDM Prius engine. What type of shenanigans is Toyota doing now?
    SFO likes this.
  3. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    There is a hose that seems to be missing it goes around towards the back to the EGR look at other motors online for that year and you'll see what I'm talking about
    SFO and RightOnTime like this.
  4. johnnychimpo
    514
    112
    Monterey
    Ever get this fixed
    SFO likes this.
  5. johnnychimpo
    514
    112
    Monterey
    Yes or no, can I put a gen 3 water pump on a gen 4 engine? Dealer only has gen 3 and my gen 4 pump died. They bolt up just fine just want to make sure also what is the difference in pumps for them to change the pump?
  6. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    I've used both. No issues, but someone claims one shaft is slightly longer or bigger. The housing on the 3rd gen is bigger but doesn't matter.
    SFO and Mendel Leisk like this.
  7. johnnychimpo
    514
    112
    Monterey
    Ragingfit likes this.
  8. Ragingfit
    189
    249
    Aurora, IL
    I drive it to work every day.
    I cut the jiggle pin on my thermostat.
    Who knows why I had to do that but no problems after that.
  9. Mendel Leisk
    41,780
    What does the “jiggle pin” do normally, why is it causing problems, what are the benefits of cutting it, and are there downsides?
  10. Ragingfit
    189
    249
    Aurora, IL
    The jiggle pin is a valve in the thermostat that lets air pass through and closes to coolant. Prius' will overheat if air gets trapped behind the thermostat.
    I was warned that I must use Toyota coolant but I didn't, so that may be where the problem lies but I have no evidence to prove that.
    If you cut the jiggle pin, the valve stays open, and air passes through and so does coolant.
    May reduce efficiency. But a car that doesn't run is 100% efficient.
  11. Mendel Leisk
    41,780
    Ah ok, so it just maybe runs a slight bit cooler.
  12. johnnychimpo
    514
    112
    Monterey
    I cut it and added an extra hole. is that too much perhaps?
  13. Ragingfit
    189
    249
    Aurora, IL
    Whatever it takes !!!
  14. johnnychimpo
    514
    112
    Monterey
    Cool thanks. out of curiosity what do you do for a living?
  15. Mendel Leisk
    41,780
    On @Ragingfit’s YouTube he’s doing pro plumbing. Very insightful guy too; I really enjoyed the commentary in transplant series.
  16. johnnychimpo
    514
    112
    Monterey
    Yes funny entertaining and insightful.
  17. Ragingfit
    189
    249
    Aurora, IL
    #977 Ragingfit, Sep 1, 2021
  18. johnnychimpo
    514
    112
    Monterey
    IT WAS THE MOTHER LOVING JIGGLE PIN!!!
    A big thank you @Ragingfit and ChapmanF
    1.car now settles between 180 - 195 F on the freeway
    in the city 140 to one 160 F is that too low?
    The process. I did
    1.flushed system with AIR hose, installed new pump new oem coolant
    2.replaced jdm outlet water with us version
    3. (KEY FACTOR) cut jiggle pin and added another hole same size opposite side
    4.made sure reservoir return hose was on the up angle (I put it above the EGR cooler link to intake.)
    5.Opend the purge valve (remove temp sensor above egr cooler if you don’t have this.)
    Filled with fresh coolant and squeezed hose next to the thermostat to get extra bubbles out. close purge valve or reinstall temp sensor
    6.put car maintenance monde and around 200F open purge valve make sure you have transparent hose so you can see air come out. I you don’t have the purge valve lift the reservoir
    tank up high and let it run you should see some air bubbles make their way in to the tank.
    7 just monitor temp should be good. GOOD LUCK.
    #978 johnnychimpo, Sep 1, 2021
    Raytheeagle and SFO like this.
  19. johnnychimpo
    514
    112
    Monterey
    Oh this was in the hose that goes to the cat. Some kinda restrictor. 16305283083544696109652910918873.jpg
    Ragingfit and SFO like this.
  20. Ragingfit
    189
    249
    Aurora, IL
    oooooooooo
