Swapping the stock CAT for aftermarket?
Discussion in 'Gen 2 Prius Main Forum' started by Jimbolimbo, Oct 4, 2020.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    It's lots of money to buy a new OE cat, but you might get much less selling it to a recycler. I usually get $25-75 for an OE cat vs $5-10 for a cheap AM cat. The Prius cat may be worth more just because it has to be better (ie more rare metals) in order to keep emissions down when the engine only runs part time. Last time I checked the government frowned on anyone selling (or buying) a used cat. If you yank all the usable parts to sell you could get more $$ if you can find buyers but the rest of the hulk won't get anything much from a junkyard.
    #21 mr_guy_mann, Oct 4, 2020
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    Yes, if you part the car you could get more money for it. It is more work though.
    If you sell the whole car you don't normally make much money for fixing things that are wrong with it, unless you can do it very cheaply.
    Jimbolimbo likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Well, it would all be true if you lived in your stated location.
    Since you now live in an undisclosed place, it is harder to judge. I tend to feel that badly about those trying to use a straight pipe. Aftermarket cats are illegal in CA, NY, and ME, but at least try to preserve air quality.
    #23 JimboPalmer, Oct 4, 2020
    Jimbolimbo and Isaac Zachary like this.
  4. Leadfoot J. McCoalroller
    8,290
    7,803
    Pennsylvania
    2018 Prius c
    Sometimes when you sit in the splash zone, you get some Internet on you. Shake it off. ;)
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    @mr_guy_mann
    Please sell me every OEM Toyota GD3 and EA6 Gen 2 Prius converter you can get your hands on. I'll even do $100 each. I may be able to go slightly higher if really needed....
    Skibob, strawbrad and Isaac Zachary like this.
  6. Jimbolimbo
    Jimbolimbo Junior Member
    17
    Global Citizen with a focus on the western USA
    If those are that poor guy's real numbers, he's going to be in tears soon...
  7. Jimbolimbo
    17
    So are you saying an aftermarket catalytic converter is just a straight pipe? That they don't do the job that they're supposed to?
    That's important to me too and would factor into my decision.
    But since apparently the oxygen sensors will work with them, I'm assuming that they do actually do what they're supposed to...
  8. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    No, he's talking about cat eliminators aka straight pipes. You would normally use an O2 eliminator in lieu of a O2 sensor too, to keep the ECM happy.
  9. lexidium
    lexidium Active Member
    304
    144
    manchester
    Just move to the UK!
    You can use a cat that is a great deal cheaper and when it has it's MOT test, they don't test the emissions on hybrid cars anyway. :D:D
  10. Isaac Zachary
    2,779
    1,501
    In lots of places in the USA there aren't any smog tests whatsoever. Here in Colorado there are no emissions tests unless you live in the Denver area.
    Sadly, because of that there are a lot of people who delete their catalytic converters.
  11. Jimbolimbo
    17
    Not an option for those of us trapped on the USA Titanic. Your country wouldn't even consider letting us in at the moment.
  12. lexidium
    304
    144
    manchester
    You're all welcome . . . . . Apart from that guy with the funny hair :D:D:D
  13. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    The non-OEM version installed in my 2nd Gen UK Prius via my insurance company was made by a reputable EU dealer called “Klarius”.
    I did visit their web page at the time and was very impressed with what I saw.
    My Klarius Catalytic Converter will soon be 2 years old fitted - my MPG has never been better, and NO error codes or emission anomalies.
    In fact “The Spaceship” just sailed through its MOT this month - the only failures were both headlight cluster units (badly yellowed, and one had water ingress). Both gladly replaced. Hybrid check was okay, no mechanical failures. 125k so far - daily 34 mile round trip commuter.
    iPhone 6s +
    SFO likes this.
  14. Data Daedalus
    1,025
    1,185
    Wembley, London
    Emissions on Hybrid cars ARE tested in the UK. The only advantage we have is that, at this time, our DMV equivalent isn’t anal about insisting on replacement OEM cats only on all hybrids.
    Non-OEMs work just fine - indeed, they’re the equivalent of the much more modern cats now installed in the latest vehicles (as OEM).
    Hence, nobody’s stealing cats out of newer vehicles.
    iPhone 6s +
    SFO likes this.
  15. caliwaves
    caliwaves Member
    65
    33
    TX
    As a theft deterrence measure, what if you swapped oem for aftermarket, and store the oem at home (assuming you live in a state that allows aftermarket cats)? Curious if that could work as a workaround? It would be a hassle but you could swap it back once you live in a “safer” area for these cars?
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Just swapped mine out for one off Amazon for $125. Direct fit manifold end but the pipe size was different it had a 2 inch od so they used a bushing to mate to the cars 1 5/8 od and welded it in. Was quick and easy.
    Cars runs fine no codes. I see no difference. $100 for install.
    Selling my OEM cat on Ebay its at $1000 right now. Lots of bidders probably go $1300.
    Painted my new cheapo cat with VHT orange header paint that has stayed on it has not burned off yet. Im hoping the idiots notice the paint and the bushing which is welded on the end right before the resonator right where they usually cut the pipe and realize its not an OEM cat and not tear my car up.
    I had preemptively bought a new donut gasket at the dealer in case mine was toast but mine was fine so were the bolts so everything was re-used. The donut is $86 at the dealer. I returned it.
    The donut that came with the cat was a joke.
    But all in all really easy.
    #36 edthefox5, Nov 29, 2020
    Data Daedalus, strawbrad and SFO like this.
  17. Isaac Zachary
    2,779
    1,501
    Emissions aren't usually visible.
  18. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Sure they are car will throw a code if emissions are not met.
    Data Daedalus likes this.
  19. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Oh, a wise guy, eh? (should be spoken with Moe's voice....:))
  20. lexidium
    304
    144
    manchester
    No they are not.: Emissions testing - GOV.UK
    #40 lexidium, Dec 1, 2020
