Sway bar links....how to remove?
Discussion in 'Gen 2 Prius Technical Discussion' started by wrothgar, Aug 23, 2022.
  1. wrothgar
    wrothgar Junior Member
    oakville, ontario
    So I've done this before...and had trouble...but I'm currently stuck with the driver side lower sway bar ....front. Ive resorted to cutting it off and not having much luck. Any hints? I can't get a good angle on anything.
  2. ChapmanF
    19,046
    What's giving you difficulty?
  3. wrothgar
    oakville, ontario
    I couldn't get to the lower sway bar Link....but I was using a Dremel. Switched to a sawzall metal Blade and all is good . Everything gets so rusty here.
  4. ChapmanF
    19,046
    I found it simpler to turn the nuts counterclockwise.
