Sway bar upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by caravan2429, Oct 18, 2018.
  1. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    2007 Prius non-touring needs better corner and high-speed handling.
    I have followed several related posts regarding chassis and suspension upgrade.
    I'm looking for rear sway bar upgrade first.
    Is Gen 1 Pontiac Vibe/ Toyota Matrix rear sway bar fitted with Gen 2 Prius?
    Or Gen 2 Pontiac Vibe/ Toyota Matrix also fitted?
    If it is, I will search for Vibe/Matrix rear sway bar.
    It seems both have sport Version ( GT/ XRS), but I don't know whether the bars are stiffer and thicker than base ones?
    Is Gen 2 Prius rear suspension same as any model year of Corolla?
    As far as I know, Gen 9 Corolla is basically same as Gen 2 Prius, How about newer model year, Gen 10 and Gen 11 Corolla? Are they still similar design?
    If so, I can look for tuned suspension parts for any model year of Corolla.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    best deal is used corolla/matrix bars front and rear. for a bit more the rear TRD or Progress bar is a super easy upgrade. front OEM corolla bar is good enough, a little more difficult to install. since you will likely have to lower the front subframe, spray paint the subframe ears so that you have reference marks when you reinstall. then get an alignment.
  3. Rivieraman71
    Rivieraman71 Active Member
    148
    195
    Englewood, FL
    To swap the front sway bar is it absolutely necessary to drop the subframe or can you get it out by removing the center exhaust pipe / lower control arms or any combo of the two? Really don’t want to drop the subframe I just had an alignment last week.
    #3 Rivieraman71, Dec 10, 2018
  4. 69shovlhed
    2,170
    744
    Delaware
    some alignment shops guarantee the alignment for a year. if they do, just don't tell em what you did.
    audiodave likes this.
  5. audiodave
    audiodave Active Member
    783
    268
    US
    When I changed the front to a Corolla one it changed alignment, camber was off.
    Mine was aligned for free since they didn't know I changed the bar.
    Replaced the bushings while at it too.
    69shovlhed likes this.
  6. Rivieraman71
    148
    195
    Englewood, FL
    If I do something that requires an alignment and it’s still within the alignment warranty I use the ole pothole excuse.
