Sway bars on gen4?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by jteran5, Jun 23, 2020.
  1. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    Has anyone changed the sway bars on their gen4? I haven't come across one thread of anyone doing it and wondering how involved it is.
  2. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Installed so far 3 sets, tricky part is that you will need to lower the Front subframe to install the front Sway Bar.
    Cusco for the Win
    iPhone ?
    TGrracie and krmcg like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is that on a Gen 4?
  4. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Here is a pic of one of the installs. If anyone in the SoCal region, give me a DM for an installation quote
    Mambo Dave, 2020XLEAWD and jteran5 like this.
  5. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    I figured the front subframe would have to be dropped... Roughly how many labor hours is this? I just ordered a front and rear set and was going to take it to a local shop for install but wanted a vague idea of how long it would take.
  6. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    It’s about 4 to 5 hours with the right tools. The rear is easy so no biggie
  7. jstevens44
    jstevens44 Junior Member
    29
    Charlotte, NC
    This might not be the right place to ask, but what benefits does a sway bar provide?
  8. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    They limit body roll on turns. Just ordered a rear one.
  9. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    Are you AWD? Just assuming based on your username. Please be sure you are getting the one for the AWD. The standard one won't fit.
    I've done both front and rear already and the car feels completely different on turns. It's amazing.
  10. Jill E
    Jill E Member
    60
    40
    San Diego
    Where did you go to buy hardrace suspension and the AWD specific sways? Zvw55 search for sways kinda zeroed me out ahaha.
  11. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Yes thanks! I’m AWD and emailed RHD Japan to make sure the send the correct one
  12. Mendel Leisk
    41,909
    Another question: there are sway bars already; you're sub'ing a stiffer, larger diameter bar?
  13. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    I got my hardrace stuff here :
    HARDRACE TOYOTA PRIUS 4th XW50 2015–present Arm, Bar and Brace, Bushing, Engine Mount, Sway Bar, Stabilizer Link and others.
    The rear subframe brace does not work on the ZVW55. It will rub on the bolts on the rear motor. Makes a slight banging sound. I still have mine on as it doesn't bother me that much.
    As for the other stuff, I've been buying from Rakuten JP and using ZenMarket as a proxy shipping service. Still comes out cheaper than buying from US vendors and plus, US vendors RARELY have Zvw55 specific stuff. However, zenmarket is EXTREMELY slow at the moment. Maybe a month to get stuff.
    Rhdjapan is also very good and I should have just ordered stuff through them but I had some Rakuten cashback and used it. Rhdjapan also doesn't have everything. I ordered some TOM'S RACING products and used Rakuten/zenmarket to get my things
  14. Max Sanchez
    Max Sanchez Junior Member
    Orange ca
    Four Touring
    I am in OC, and I was wondering how much you would charge for installation on a 2016 prius?
