Sweet upgrades-priusv
Discussion in 'Prius v Accessories and Modifications' started by tommy Wang, Jan 29, 2019.
  1. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Thanks to Masta Sean and Roger at hybridPit for their hard work on retrofitting my JDM Prius v G's lights and help me put together other goodies onto the car. i can finally say Goodbye to my crappy Halogen head lights and the new lights are Awe-and-some!
    BTW: Masta Sean, the corner ambient lights are now the DRL.LOL..that was a surprised!
    Also, super fun to meet up with so many Gen 3 prius guys at the shop and seeing their mods in person (sorry i am terrible with names)
    • JDM Prius G's headlights
    • Retrofitting wiring
    • Fog Light Toggle stalk
    • Morimoto Led Fog lights
    • Premium Horn
    • GR Sport push button (JDM) (white led when Lit)
    • Carbon Shifter (JDM)
    m.wynn likes this.
  2. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Wow, can they do Li-ion retrofit with third row seats? That’s some nice work!!!
  3. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    May be? They are pretty handy with all the Prius work they done at the shop when I was there
  4. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    I thought i was going to STOP with the Head lights JDM and Fog conversions, but now it's turning into Prius A GR Sport conversion thread:cry: (my Poor wallet)
    Thanks to my friends from JPN/ TW and Audiocityusa to help me put together parts:
    Round 2 parts list:
    • S-Tune package with Piano Black steering wheel controls (JDM)
    • G's Black out tail lights (JDM)
    • G's OEM suspension kit (JDM)
    • Toyota shark fin antenna
    • Avest Vertical arrow turn signal (Bronze)
    • G's projector courtesy light
    • Prius A led door sills- (only because is 4 pcs not 2 from JDM toyota)
    • Rotiform R154 18x8.5 Anthracite/ Falken ZE912 225/45/18 +35
    • G bumpers and side skirts are Pending
    • GR Sport emblems
    • More RE audio goodness later
    :whistle::whistle:
  5. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Original Tail light removal and installed the JDM G's Tail lights: *** Do this at your own risk!!! i am not responsible or liable for any damages you may cause by repeating this tutorial****
    Preparation:
    1. Use masking tape around the outer edge of the body panel and bumper area (preventing any accidental paint scratch during the removal process)
    2. Use a pry tool to open the rear panel inside the trunk area
    3. There are 3 screw nuts holding the housing (showed in red arrows, remove the nuts by using a 12 mm wrench)
    4. Unplug the power connector from tail light
    5. Before you begin pulling the tail light, notice the 2 red circles (Left side is a Tab guide, top is fitting pin insert)
    6. The arrows are the screws which was held by the nuts you remove earlier
    When pulling the tail light:
    • Waggle the tail light side to side (with both hands on the tail light, slowly loosing the bolts, tab guide)
    • Stand close to the tail light and use your right hand to grab onto the upper portion of the tail lights between the gap of the body and tail light.
    • With your left hand holding the left outer housing, and your right hand fingers from upper tail light housing against the body panel
    • Slowly pull and push against the body panel toward you. (you will feel a pop of the tail light fitting pin separates from the upper fitting pin insert on the body panel)
    • Slide the housing toward you. (DO NOT Force it out which may damage the guide tab on the left side)
    • there are 2 gaskets on the body panel which will need to be removed and place back onto the new tail lights screws (top screw and most outer screw near the left side) ***those gaskets are for water proofing, make sure you put them back onto the new tail light***
    • Repeat the same procedure on the Right side tail lights
    Few things to watch out for when reinstalling:
    • Install the new tail light from the outer tab guide and the fitting pin/ fitting pin insert is located.
    • Check your tab guide is sliding against the tail light guide rail and pop the fitting pin into the pin insert.
    • Firmly press down the top portion of the tail light and replace the nut back onto the top screw and secure first (due to tightness of the space, you will have to be very careful when placing the nut back on)
    • Place all nuts back onto the screw and lightly secure them (do not over tighten)
    • Check the upper portion of the tail lights edge is seated inside the slope of the body panel (this step is to ensure water will run above the body panel and away from the cavity of the tail lights.
    Now enjoy the look of the new tail lights(y)(y)
    #5 tommy Wang, Feb 8, 2019
    icyrius and m.wynn like this.
  6. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    now the Tail light is JDM-ized. which one would you preferred? that Chromatised look or the stealthily look?
    Awaiting arrival of some oem parts prepping for a few minor upgrades:
    • Mirror covers (prepping for the Sequential turn signal): Toyota 87945-74010-P0, 87915-74010-P0 (wrap in 3M Piano Black)
    • Shark Fin: Toyota 86300-12B30-C0 (Replacing the outdated antenna on the roof)(Test trial)
    • Rear Suspension bolt replacement: Toyota SU003-05213, SU003-05235 (base on reviews i have read, the bolts add rigidity to the rear shocks and axle beam) :rolleyes: These bolts are made for rear engine mount Toyota GT86, FRS. maybe a Placebo effect, will find out soon.
    • Engine Hood lift: Toyota 53337-75010, 53336-75010, 68961-20140 ( gas struts ebay after marker 20 dollars)
    here are all the part numbers, in case anyone were interested in those mods.
  7. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    After testing the Shark Fin. FAIL!! i guess i forgot to cross reference US radio antenna which has the additional plug (for that XM radio thingy) but i was still able to install it and kept the original antenna base tie down inside the quarter panel.
    After testing: FM,AM, Navigation and phone all works. Only thing i lost is the XM radio which i do not use. Love the look of the roof line :p
    Using this link to remove the headliner and all the trims (page 1-10): lots of Japan goodies just arrived today. :D:D:D Valentine gifts for my Car.LOL
    #7 tommy Wang, Feb 15, 2019
  8. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    3 weeks of rain and SNOW in LA..which is the oddest weather we had in Socal, finally had the chance to install the new wheels and turn signal mirrors.
    After the terrible vinyl wraps job by me on the mirror cover. I decided it is best to keep my day job and leave that to the professionals on a later day. (still deciding if i want to match the color of the car or blacked out to match the lines of the window) The original dark gray mirror cover color seems to blend well with the wheels, and lower grill color.
    Thanks to the help of AudioCityUSA to complete this round of installs. here are the results:
    • Avest Vertical arrow turn signal (Bronze Gold)
    • Niche Verona M150 wheels 18x8, +40, 29 lbs
    • Falken Ze950 225/45/18, 24 lbs
    I highly recommend the Avest turn signal mod!! These feature should of came stock on the Prius models. DRL, Sequential turn signals, and foot light
    hopefully weather will warm up next week to give a good bath and wax.
    still awaiting for the OEM G's suspension to arrived from Japan and install.
    hope you guys like the look of the car:love::love:
    #8 tommy Wang, Feb 22, 2019
    Long Beach Comedy likes this.
  9. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Prius v Interior upgrade is completed in Piano Black! LOVE IT! it is a good upgrade for the interior.
    During the installation of the steering wheel switch pad controls, i was worried that i might pop the airbag. After removing the steering wheel cover, i actually didn't have to disconnect any of the airbag wires. i have full access to all the screws holding down the switch pad controls.
    I did disconnect the Negative wires on the battery after removing the cover. (Just in case) but overall the install was simple and just have to find a way to hold the steering wheel cover in a position that i can free up my hands to work on switches.
    IMO, Piano Black panels is a much better look then the Dark Silver finish which came with the v. i will update more photos (raining cats and dogs Again in Socal )
    Parts used:
    • 3M 1080 Piano Black Vinyl wrap on all door panels contorls, and center console
    • JDM Toyota G's S-Tune Black Edition steering wheel switch pad contorls
    • Avery Blue metallic Vinyl wrap to remove all the chrome accents
    • Ebay Blue Chrome trim finish on the interior door panels.
    Burna J likes this.
  10. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Did some minor interior upgrades to reduce wind noise and door cushioning. Does it help? somewhat, i guess.
    the rubber seal does it's job on reducing the noise when you closed the doors and overall cabin noise is quieter then before. Base on non-measurement estimate of -5 to may be -8 db reduction in wind and road noise.
    Ebay Weather strips:
    • Z type EDPM rubber seal for A piller
    • B type EDPM rubber seal for B and C Piller
    • P type EDPM rubber seal for bottom of doors
    • B Type EDPM Rubber seal for engine bay
    Project #BluemonsterGRsport and all the parts are on order just waiting for arrival.
    • Tein Flex-A Coilovers
    • GR Sport Front, Grill and Rear Bumper
    • GR Emblems
    Long Beach Comedy and Air_Boss like this.
  11. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Very nice mods.
    May I ask, with your piano black steering wheel trim, is there a piano black elbow rest/ door (all 4 door) panel window switch panels in your future?
  12. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Unfortunately Toyota do not make the Piano Black door handle trims for Left hand drive cars, only JDM Right drive cars on their G'S and GR models.
    I vinyl wrap all the door handle trims. (excused the terrible job, i am newbie on wrapping) i will re-wrap the trim pieces when i order a sample of this vinyl to see if they match the Steering wheel trim pieces.
  13. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    #bluemonsterGRSport Gets some love this weekend
    • 3M Black Galaxy Vinyl wrap-with Sparkles :love::love:
    • Prius a aftermarket White Led scuff Plates front and rear
    GR Sport JDM bumpers, side skirts, Prius a GR suspensions, K-spec front bumper Splitter finally on the boat awaiting arrival..
    the waiting and waiting is killing me!!! Cannot wait for the final results.
    icyrius likes this.
  14. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    4114638D-06E5-476F-AD42-73E221F9C1F3.jpeg Lola got her badge.
    tommy Wang likes this.
  15. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Any 2012-2015 Prius v owners are considering conversion to 2016-2017 versions? I have basically everything you need!. if anyone is interested!
    Front, Rear bumpers, Halogen headlights, tail lights, 2 type of lower grill (fog light version, Non-Fog version) All less than 23k miles.
    JDM GR sport Front and Rear bumpers, Kspec front lip arriving next week. And I found a awesome deal on Toyota JDM Chassis Membrane that came with the 2017 up JDM G's and GR models..Prius v. No need to order all those Cusco's bars.
    the kit comes with 1,2,3 and A, B, C only thing i cannot find is the Rear bumper membrane
    :ROFLMAO::ROFLMAO::ROFLMAO:;)
    MVPLRJohnson likes this.
  16. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
  17. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    Why did Toyota remove the 3rd air vent from my 2017..that would come in handy when i have passengers in the back seat.
    Nice knob!
    Georgina Rudkus likes this.
  18. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
  19. prevailz
    prevailz Junior Member
    Southern California
    2014 Prius v wagon
    How much for the rear bumper cover? I may be interested.
  20. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    sorry just to clarify Read bumper "cover?" you meant the bumper protector? or the whole bumper? Thanks
