Switched off 07 Prius during initial ICE cycling
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ystasino, Jun 11, 2007.
  1. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    I accidentally powered off the Prius while the ICE was cycling. My senses of reason and routine are weak in the morning.
    I didn't see any ill effects after restarting it but I'm wondering what would canceling that initial cycle repeatedly do to the Prius except to improve mpg.
    Thanks
  2. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I've shut down at what seemed inopportune times. I question it at the time but them just move on.
    I would not foresee any problems but would also avoid doing it regularly.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It would be a poorly engineered vehicle that lets you shut down when it would cause harm. The Prius is anything but poorly engineered. You would have to start yanking wires or fuses to cause any shutdown problems.
    Tom
  4. dogfriend
    7,512
    1,185
    Carmichael, CA
    It seems to me that the Prius is more immune to this sort of "abuse" than a normal (non-hybrid) vehicle. After all, the thing is designed to start and stop the ICE at the command of the Hybrid ECU, not based on driver input. The oil pump is already pumping oil to the bearings before the Engine ECU adds fuel and spark. The reason the ICE stays on longer initially is to get the Catalytic Converter up to temperature so that it is effective at lowering emissions.
  5. Jimbo913
    Jimbo913 Junior Member
    25
    Maryland
    A bit unrelated question but has anyone figured out how to command the ICE to kick on and stay on? I would prefer to command it on in bumper to bumper traffic when the battery gets low to avoid constant engine cycling. I wish I could intervene in order to charge to at least two bars above middle instances like this.
  6. bisco
    49,089
    no, you can't control it. there is a hidden maintenance screen that allows you to run the engine, but it wouldn't work while driving.
    prius have been cycling the engine to charge the battery for 20 years with no known ill effects.
  7. Starship_Enterprius
    Starship_Enterprius Active Member
    313
    152
    Ottawa, Ontario
    2018 Prius Prime
    I'm not entirely sure it will work, but the 2 times I forgot to put it back to from B mode going downhill, it wouldn't shut off at a stoplight. Scared me to death thinking something was wrong with my Prius.
    Try putting it in B mode and let us know.
