Switching back to EV during HV warmup
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Aug 23, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    Obviously this doesn't work if you are out of EV, but does anyone else do this? I figure I am essentially still in EV during the warmup cycle so I'd prefer to have that HSI up instead of the HV one.
    I am correct in assuming that the warmup cycle routes power and everything the exact same regardless of whether you are in HV or EV?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The warmup in EV mode revs at 1,500 rpm.
    I am not sure if it is different than a regular Prius or PiP in HV mode. I know for sure Gen2 Prius revs lower during warmup.
  3. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Once the ICE starts you can't do EV operation until coolant temperature is reached, 160F for the PiP, 130F for the non-plug-in. On a cold winter day that could take quite a while and lots of gas. That's why folks with a PiP and a full battery try to keep the ICE off until it is need to run the car. They do that by not "stomping" on the accelerator and not letting regeneration try to charge the battery if its already full.
  4. markabele
    5,084
    1,782
    Nebraska
    I guess I wasn't thinking full EV, just EV mode with little outline of the car.
  5. stanwagon
    stanwagon Junior Member
    64
    2013 Prius Plug-in
    I am starting to dread winter up here (10000 ft in Colo), when the ICE might end up running for the full duration of a trip of 5-7 miles.
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Use heated seats. Air heater will turn on ICE but it will shutdown after 0.03 gallon.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Yup. I routinely toggle the button, pushing it to start the engine with the want for it to automatically switch back to EV (or boost) as soon as warm-up is complete. The effect is the same as just dropping the pedal to fire up the engine. It doesn't matter when our how.
  8. john1701a
    12,840
    5,311
    58
    The standard warm-up thresholds are 130°F for the plug-in and 145°F for the regular. Engine off is 114°F for both with in ECO.
    usbseawolf2000 likes this.
  9. CaliforniaBear
    1,180
    289
    Northern California
    You are correct 130F before the ICE will shut off. I'm pretty sure When I had a standard Prius it was happy at about 106F. My ECO is always on.
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    106, that's spa temp.
