switching to 10w30??
Discussion in 'Gen 2 Prius Main Forum' started by atown636, Feb 26, 2020.
  1. atown636
    atown636 New Member
    AZ
    I recently purchased an 06 with 177K, i live in arizona, and the summer can be really hot (110+). Since I've had the car, I've been looking here on the forum for most of my questions, and i say people mentioning 5w30, as the recommendation
    Now for owners of a pruis with high mileage (177K) and living in a hot state, would y'all recommend sticking with the 5w30 or switching to the 10w30.
    Also my car also consumes a lot of oil. hoping a thicker oil will slow this consumption down.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    At operating temperature 10w-30 and 5w-30 are just as thick. Beginning part 5w, 10w (or 0w) describes the thickness when cold. End part -30, -40 (or -20) describes the thickness when hot. In both of them bigger number means thicker. Hot and cold aren't in same scale so it's not actually thicker when hot.
    So just hot weather is not a reason to move from 5w-30 to 10w-30. They are the same thickness when hot. If for some reason you would need thicker oil options would be 5w-40 or 10w-40.
    How much oil is it consuming? Is that really enough to be thinking about stuff like this?
    edthefox5 and Aaron Vitolins like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,103
    5,815
    Columbia, SC
    If I ever get one of my engines to it's end of life, where it's consuming more than a quart every 1k miles, I'm just going to go right to the top of the common spectrum and do 20w-50. Depending on how it does, I'll start mixing in 90 weight gear oil. Just to see what happens.
    M in KC likes this.
  4. ydpplqbd
    ydpplqbd Active Member
    542
    250
    I have a 2006 Gen2 Prius with 211k miles. At first oil change, I switched to Shell Rotella 10W-30 which worked OK. Subsequently, I have switched to Shell Rotella 40W (from TSC). 40W seems to slow oil usage and I even may have gotten a small mpg boost (say 3/10 to 1/2 mpg). Just my two cents ("$0.02").
    PS 40W seems to reduce blow-by. With 40W, I get less spoils in my after-market catch can than with 5W30 or 10W30. My theory is that the 40W reduces blow-by. Blow-by is what propels the spoils from the PCV valve into the catch can.
    #4 ydpplqbd, Feb 26, 2020
  5. atown636
    atown636 New Member
    AZ
    can't say for sure, only driven 1k miles, and did an oil change the day i bought it. i would guess maybe close to a quart in 1K miles, but there seems to be a small leak coming from the front cover(passenger side) also might have to the contribution of the oil consumption I'm seeing
  6. dolj
    dolj Senior Member
    7,512
    3,774
    Wellington, New Zealand
    You do realize that 40W will be a lot thicker when cold, so you are making it more difficult to get the oil to where it needs to be on start-up. Start-up is when most damage is done and why the first number on newer oils is smaller - 0W and 5W for example. As Valde has pointed out, if you want to experiment with thicker oils you should be increasing the second number which is the hot weight.
    Have you tried either 10W-40 or 20W-50? These would be superior choices in my book.
  7. valde3
    2,002
    745
    Finland
    Quart per 1K miles is bad but not horrible. You could try something like 10w-40 to see if that makes it better (or worse) next time you do an oil change. Before that you will know the oil consumption rate more accurate anyways. Wait for at least entire oil change interval before coming to a conclusion about change in oil consumption rate.
    Oil leaks need to be fixed anyways. But make sure the leak is actually coming from front cover seam before doing anything about it. Sometimes valve cover gasket leaks look like front cover leaks.
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Mobile 1 sells a 5 qt jug of 0w40 for $25 at Walmart. 0w40 might just be the perfect oil for these old 1.5 engines. Easy start up, but thicker oil and better protection at operating temperatures.
    edthefox5, dolj, Raytheeagle and 2 others like this.
  9. ydpplqbd
    542
    250
    Most recent oil change after almost 4500 miles (a little more miles than I normally shoot for) revealed that my Gen2 consumed about 1/2 quart in the almost 4500 mile interval. For the prior oil change (and current oil change), I used Shell Rotella 15W-40 T4 (I believe that this is Shell's designation for synthetic oil). Additionally, there were no spoils in my after-market oil catch can. My Gen2 continues to provide gas mileage in the 48 to 51 mpg range.
    Conclusion: My Gen2's 1.5l motor continues to consume oil but oil consumption has now been reduced to 1/2 quart of oil consumption for almost 4500 miles (about 1/3 of the oil consumption rate when compared with the rate occurring when I first acquired my Gen2).
    #9 ydpplqbd, Aug 2, 2020
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    It is T6. And now they have a T6 formula for cars too.
    The original was for diesels but worked fine for cars and motorcycles.
    I don't know what the difference is with the new stuff but assume that there is no zinc (for cat converters) and a bit of moly for decreased friction.
    ydpplqbd likes this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Listen to Aaron.
    I have been running 40 weight Redline oil for about 2 years no mileage hit and it stopped the minor oil loss i was starting to see.
    Run that M1 0-40. Good buy great oil Go 5000 oci or until the oil on the dipstick really starts to stink of fuel.
    Aaron Vitolins likes this.
