Switching to Hybrid before Freeway
Discussion in 'Prime Main Forum (2017-2022)' started by PorscheBoy, Jan 20, 2019.
  1. PorscheBoy
    PorscheBoy New Member
    When I'm driving to the freeway in electric mode, I often manually switch to hybrid mode a few minutes before getting on... I'd rather let my engine warm up before subjecting it to 75-85mph speeds.
    Anyone else do the same?
    upnorth and bisco like this.
    52,654
    exactly, better safe than sorry (y)
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Yeah, I do, but it's also the way to get the best gas mileage given my commute, and that's my main reason for doing it.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    The battery and electric motors assist the engine a LOT while the engine warms up. Try switching to HV with a cold engine at highway speed and watch the remaining EV range continue to drop while you keep getting at or near 100 mpg for a while. Once it warms up, mpg will drop below normal for a while as the ICE puts the energy back that it borrowed from the battery. It's an amazing machine!!
    upnorth, EyePrime and PorscheBoy like this.
  5. ed4271
    ed4271 Member
    107
    64
    US
    I agree letting the ice warm up is a good idea. What I do is when I leave the house I'm on HP into the engine warms up and then when I get on the highway I switch to EV mode. My distance from my house to work is only 14 miles. I easy start off with 25 EV miles even in the cold weather. By that time I arrive at work I have either 10 to 8 EV miles left. So on the way home I'm on HV mode. Seems to work out well. Then I charge it to my 240 volt chargepoint level 2.
