Sydney Taxi T4514 - 3 years of running
Discussion in 'Gen 3 Prius Main Forum' started by AussieOwner, Dec 29, 2014.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Holly macro, that's 109,000mi annual!
    (for comparison avg mileage of NYC cab is ~21,000mi)
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    That can't be right - for the NYC cab. I was covering 35k miles a year and there was just me as an owner driver. Cabs that are double manned run 70/80k miles a year easy. Some company cabs that are run 24/7 will cover 100k+ a year. My old company cabs would have around 300k miles on them at 3 years old, and that's just in a small town.
  3. clayton4115
    clayton4115 Junior Member
    60
    brisbane australia
    ok thanks, so an adult mountain bike should def fit in the prius with the passenger seats down
  4. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    Yes. I recently carried "an adult mountain bike" and a 61 cm road bike in my Prius simultaneously. Also, the mountain bike and three humans (including driver) simultaneously.
  5. AussieOwner
    AussieOwner Active Member
    1,091
    67
    Sydney, Australia
    According to the NYC taxi fact book (http://www.nyc.gov/html/tlc/downloads/pdf/2014_taxicab_fact_book.pdf) the average NYC cab runs approx 70,000 miles per year.
  6. cyclopathic
    3,292
    547
    2014 Prius c
    I saw that too. The 21K came from insurance rag, so not sure if the diff is cabbie vs cab or they just quoted wrong #s. Irreguardless it is a lot of miles.
  7. myPriusAcct
    myPriusAcct Junior Member
    29
    17
    Do you follow the Australian Prius manual/fuel lid instructions and put Premium 95Ron petrol in the taxi or do you put e10 in it? USA owners seem to have regular 87 gas recommended in their manuals but also get pretty poor mileage on fuelly stats. I consistently get 3.8l/100km and always assumed this was due to the fuel requirement for Australian models until I saw your stats. I'm surprised your consumption average is 4.95l/100
  8. AussieOwner
    1,091
    67
    Sydney, Australia
    I use Premium 95RON.
    As a cab, I cannot always drive to minimise my fuel consumption. Also, on hot days, if I am stuck on a rank, because I always leave the power on, the air con drains the battery and thus needs to kick off the petrol engine to top it up. I have noticed that my fuel consumption always goes up when I have a slow day.
  9. AussieOwner
    1,091
    67
    Sydney, Australia
    Woe is me!! Just on a month ago, I had an early fare to the airport. On the way back, it started to rain, then rain heavily, and finally it was really bucketing down. Just for half an hour. As I neared home, I headed down a road that is subject to flooding. It is not well lit, and as I got around a corner, I could see water across the road. There was a car slowly moving through in the opposite direction, and I did not think that it was too deep.
    Wrong!!! The road dips on my side of the road, and the water got up to about knee height. I got through, but just as I was climbing back onto dry road, the dash lit up like a Christmas tree and the car staggered. I could just get out of the way, and off to the side of the road, but then the car was dead.
    Found that I had got water up over the engine, through the air filter, and into the manifold. Once the workshop had stripped the engine, found that I had bent the conrod. Solution - buy a new motor. Given the low number of Prius in Australia, this meant that I had to get the engine from Japan, so the car has been off the road for a month. Finally got it back, all fixed, today. So now I will have to work extra hard to pay for it all.
    So a warning to all - be very careful in driving on flooded roads - it appears that it is very easy to get water up over the engine, and you do not want that to happen.
  10. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    Long ago, I knew a kid who plowed just a little too close to the pond with his father's diesel tractor. It toppled and landed upside-down in the water. Result? Exactly the same as for your Prius. Water's hard to compress.
  11. Emcguy
    Emcguy Member
    176
    29
    Australia
    I found, that on a recent trip to Sydney,it was very hard to get E10 rated at RON95. It all seemed to be 87 that had been bumped up to 91 obviously resulting in cheaper costs. In Victoria United fuel is the only one that guarantees 95ron e10, although caltex is close with 94 e10. The bottom line is, if I can't go to a Victorian United, i will always buy premium.
  12. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    It floods all the time here and you never ever drive through water on a road you don't know. Many areas that flood often will have a depth marker but if it doubt, turn around. A city near me floods all the time and sometimes you don't have an alterative route. I'd always make sure I had enough battery charge in the car and then drive through the flood slowly in EV mode. The main concern doing it that way was not engine damage but flood water coming into the car - you really don't want that!
    To AussieOwner, did your insurance not pick up the tab? Over here if you've got Comprehensive cover they'll pay for engine repairs due to flood damage so long as it's cost effective. I'm guessing taxi insurance is as expensive over there as it is here but even considering that, a claim for a signficant engine repair might be worth doing.
  13. myPriusAcct
    29
    17
    Caltex e10 is 91 RON. It's Shell E10 that is 94 RON. See my references below.
    United e10 - 95 RON
    www.unitedpetroleum.com.au/united/fuel/unleaded-e10
    Shell e10 - 94 RON
    www.colesexpress.com.au/shell-fuels/shell-unleaded-e10.aspx
    BP e10 93RON
    www.bp.com/content/dam/bp-country/en_au/media/fuel-news/fuel-octane-power.pdf
    7-eleven e10 (exxon mobil) 93RON
    www.exxonmobil.com.au/Australia-English/PA/products_fuels_ethanol.aspx
    Caltex e10 - 91 Ron
    www.woolworthspetrol.com.au/our-products-and-services/
    #33 myPriusAcct, Feb 20, 2015
    Emcguy likes this.
  14. Tideland Prius
    16,542
    Oye! Closest I got was just shy of the bottom of the car. The clue that stopped me from going further was the water was up to the door sills on the police car parked on the road which meant the water was deeper up ahead. I backed up and parked the car elsewhere with the front of the car on higher ground.
