Sympathies for TransAsia Flight 235 Crash
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Feb 4, 2015.
  1. bwilson4web
    16,124
    True but framing can be terribly misleading:
    • Flying is safer per mile - true
    • Flying is deadly per hour - true
    A Prius example, I flew from Huntsville to Fort Worth to pickup a 2003 Prius. Then I drove 800 miles back:
    Flying is so much faster than driving that the risk exposure per mile is significantly lower. For example, when I flew out to Fort Worth to pickup our 2003 Prius, it took ~1,200 flight miles including connecting at Atlanta just under 6 hours. The return drive, 800 miles, took ~52 hours including a sleep-over, and fuel/biology breaks. Driving took 52/6 ~= 8.5 times longer. Had either plane crashed at landing speed, it would have been at over twice the average speed, ~4 times the energy, compared to the Prius average cruise speed I drove.
    Here I've done some framing by inflating return trip with a 6 hour sleep over, 2 hour breakfast break, and a couple of 'cat nap/walk a bouts.' But the effect is minor, 800 miles driven with an average speed of ~60 mph, about 14 hours on the road. Take out the Atlanta layover, it was about 4 flight hours so actual travel risk, ~3.5 times shorter on the flight. The 'magic' of framing converts statistics into whatever you want to sell.
    On a serious note, this was used by the NHTSA and blind advocacy groups to trick a Senator into claiming our Prius are twice as dangerous to pedestrians as ordinary cars using statistical reports that cited no fatalities. Closer reading revealed the statistics are real BUT the framing at best misleading.
    Source: NHTSA Delays Requirements For Electrified Vehicle Alert Sounds - HybridCars.com
    I suspect an honest statistician at NHTSA has realized what happened and I am not surprised there is a delay.
  2. ETC(SS)
    7,061
    But liars can use stats.....
    bwilson4web likes this.
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    and frequently do
  4. bwilson4web
    16,124
    I heard on the morning news that the 'good engine' was shutdown BUT like many preliminary reports, subject to revision. But there have been cases of the wrong limb amputated which is why now the medical staff prepares a patient with a magic marker to identify where the procedure is to be done.
    ps. Sorry about the diversion on statistics. My professional career I've used statistics to keep myself from falling into 'traps' from cursory data. Of all the math I took in college, statistics is the one I return to including a not-dusty "STATISTICS FOR BUSINESS AND ECONOMICS" bought 6 years go, used college text, when I could not find my other reference book. A 'business' book designed for quick reference . . . for simple minds or those in a hurry. <GRINS>
  5. GregP507
    3,002
    481
    Most of the "stats" used in advertising are not stats at all, but made-up to sound like stats. OK, enough diversion.
  6. ETC(SS)
    7,061
    I don't have any stick time with twin turbo-props so I'm holding off on jumping to conclusions until after they review the data recorders and other sources.
    I imagine that you'd have to reduce power in the starboard plant if the port engine goes T.U. on climb-out in addition to other stick and rudder inputs but I simply don't know what happened.
    It's easy to specuguess wrong based on early evidence.
    When I looked at the pics, it appeared to me that the prop blade pitches were noticably different for port versus starboard and I believe that I read that both plants had been recently replaced and there was a engine gripe for the bird....but we'll know a lot more when they review the data.
    It appears that 15 people survived...and nobody died on the ground....so it could have been a lot worse!
    Diversions?
    I spend half of my day at what my wife calls "chasing squirrels!" :)
  7. Former Member 68813
    3,524
    983
    US
    i'm not a pilot, but it looked it stalled and fell to the ground because the pilots maneuvered it to avoid crash with the tall buildings. why the engines failed? have no idea.
  8. fuzzy1
    10,337
    I should have noted that while the airline deaths are quoted on a per mile basis, the actual incident rate is much more closely tied to takeoff-landing cycles than to actual miles flown. So the shorter the trip, the less compelling the flying-vs-driving difference becomes.
  9. GregP507
    3,002
    481
    I believe air travel wins on distance traveled, time spent traveling, and crash survivability.
  10. Former Member 68813
    3,524
    983
    US
    interesting. lets say the typical drive is 5 mile and average flight is 500 miles. under those assumptions, the risk of dying is the same per trip. i wonder what the actual numbers are (too tired to search). also, are the commercial flying safety numbers just for USA or worldwide?
  11. GregP507
    3,002
    481
    I believe it's approximately 200 times safer to travel by air compared to automobile.
  12. bisco
    51,540
    now let's say you put a yahoo in a plane like there is every day on the highway during the morning and evening commute, speeding, weaving in and out of other planes, changing elevation willy nilly, then see how safe it is. then throw in some over tired truckers with unstable loads...:p
  13. tochatihu
    tochatihu Senior Member
    9,656
    3,724
    Kunming Yunnan China
    2001 Prius
    There is no doubt that Fuzzy1 has well described the basis of powerplant efficiency. HKMB pointed to runway 'resources", that limit equipment choices on particular routes.
    I was only trying to make the point (overlong as usual) that among 50-70 pax twin turbo props, there is a surprising range of (single-engine) power/weight ratios. On 99.(many nines) percent of flights this is irrelevant because both engines are operating well. so I was only referring to a small corner of operating envelop.
    For the current crash, much more important is whether the carrier is maintaining well, and training well for the most dangerous phase of any (non-military) flight, which is climb-out. What some particular factors here (preflight or CRM) may have pushed this flight into that bad corner.
    As always for such things I commend your attention to PPRUNE.
