Symptoms of dead 12V but charger says battery full?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Sep 22, 2021.
  1. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    A 3 amp charger just doesn't have enough power to charge a dead battery. Sometimes, people have to trick the charger by connecting a second battery in parrallel with the dead battery, so that the charger can sense that the battery being charged is not below the acceptable voltage for charging. Once the charger starts its charging cycle, it is supposedly OK to disconnect the second battery from the battery being charged.
    However, like I mentioned earlier, if you have a 7 year old original battery, it's time to replace it. A lot of batteries have a date of manufacture on it for warranty purposes.
    berderder likes this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    The sensor circuit in the charger gets "confused" when it tries to charge the battery but no current flows.
    That is, the battery will not accept a charge. AND it won't give back whatever charge that it has either.
    Typical symptoms of a totally failed battery.
  3. sam spade 2
    7,035
    2,801
    2017 Prius c
    HEAT kills batteries.
    COLD is actually good for them.......to a point.
  4. sam spade 2
    7,035
    2,801
    2017 Prius c
    That really isn't true, in general.
    It depends on how "dead" the battery IS and why.
    If the battery hasn't failed completely, a 3 amp charger is plenty but many hours will be required.
  5. berderder
    berderder Junior Member
    69
    Connecticut
    Just out of curiosity, does anyone see the manufacture date on here? 1.jpg 2.jpg
  6. xliderider
    8,140
    3,276
    Honolulu, HI
    The date of manufacture, might be the one printed in the middle ending in 13.
    It's a 2014, so it might be the day of the year (xxx out of 365), or the week, and 13 is the year of manufacture. So maybe the 311th day of the year 2013?
    But that's just a guess.
  7. berderder
    69
    Connecticut
    Yep, I think it’s October 31, 2013. Ooo spooky
    bisco and xliderider like this.
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,135
    6,298
    Texas Hill Country
    Did you get a new battery?
  9. berderder
    69
    Connecticut
    Picking up a TrueStart first thing in the morning, havent needed the car straight away
    #29 berderder, Sep 23, 2021
  10. sam spade 2
    7,035
    2,801
    2017 Prius c
    Be sure that your new battery is fully charged......before it is put into use.
    That can be done before install or after, makes no difference.
  11. berderder
    69
    Connecticut
    It should come fully charged when I purchase it, shouldn’t it?
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    Not necessarily, it sits on the shelf slowly losing charge. It's always a good idea to charge it up, before or after installation.
    FYI, I thought my batteries were going bad because my charger would never get to full charge. Turns out that the charger was the one going bad. Bought a new one and it charged up the two batteries in short order.
  13. sam spade 2
    7,035
    2,801
    2017 Prius c
    You would think so.
    But people are lazy and incompetent these days.
    And ones you get "mail order" are guaranteed to be flat most of the time.
    Unless they can hook a meter to it before you leave the store and SHOW you that it is 12.8 volts or more.......then don't assume anything.
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I had a battery that I just turned in to Walmart for core credit. My 14 A Schumacher Ship 'n Shore would charge it up to 100% real quick. If I unplugged it and plugged it back in about 1 minute later, it would start off at 1% and continue to charge up to 100% rapidly. Pretty much a dead battery. You can test yours similarly, disconnect your 3 A and then 1 minute later plug it back in. If it starts charging again and takes a while (because yours is 4x as slow), it is likely a dead battery. It should show full after only 1 minute.
    (BTW- I have two of those exact same units now. I'm slowly replacing the Automatic voltage sensing 6 V/12 V 1.5 A Schumacher maintainers as they mistaken dead batteries as 6 V and I find them DEAD, like the one I just replaced. Only negative is they come with permanent clamps and no swappable ring terminals).
  15. rjparker
    10,135
    6,298
    Texas Hill Country
    Your new Toyota battery will be fine. The high areas of expertise around here center around 12v batteries and egrs causing all sorts of issues from cancer to illegal immigration. Add in no starts and head gasket failures and you have a perfect storm.
      • The only warranty replacement battery approved for your Toyota vehicle.
      • Meets or exceeds Toyota specifications for all vehicles.
      • The exceptional 84-Month Warranty!
      • 24-month FREE Replacement.
      • 60-month proration in a simple two-tier priced plan.
      • Includes Towing and Installation Labor.
      • Coast-to-Coast warranty service at more than 1,200 locations!
    #35 rjparker, Sep 24, 2021
    jerrymildred likes this.
  16. Mendel Leisk
    41,406
    The EGR can be hard on your poor aching back.
  17. sam spade 2
    7,035
    2,801
    2017 Prius c
    And then you go on to spout off a lot of things that while likely true, have NO bearing on whether or not the battery will come from the dealer with a full charge in it or not.
    :rolleyes:
  18. burrito
    burrito Active Member
    274
    114
    When you go to pick it up, just ask them nicely to check the voltage for you, and ask them to show you the date code sticker(s). Mine was 2 months old, and IIRC was at 13.1 volts. I was happy with that.
  19. Mendel Leisk
    41,406
    Geez, spring for a cheap multimeter at least, check for yourself?
    Again, voltage alone is not a very good indicator of battery health; acquiring something like Solar BA9 ($50~ USD electronic load tester), you’re set.
    #39 Mendel Leisk, Sep 25, 2021
    Grit likes this.
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Most will reply nicely, I don’t have a meter here to measure it. Been there asked that.
