Synthetic oil
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Aug 28, 2022.
  1. nudriver
    nudriver Member
    283
    32
    los angeles
    What's the cheapest I can hope to get full synthetic 5w 40 oil in 5qts? Would it be on Amazon over an auto parts store? What do you consider a deal?
  2. JC91006
    16,923
    8,634
    costco 5w30 synthetic oil is cheapest. a prius does not use 5w40 grade
  3. nudriver
    nudriver Member
    283
    32
    los angeles
    Mine does. Engine issues. I need a PRICE.
  4. JC91006
    16,923
    8,634
    $20 per 5 quarts, if you buy in bulk. It use to be $66 for 20 quarts, but that was a month ago, before the inflation increase
    nudriver likes this.
  5. nudriver
    nudriver Member
    283
    32
    los angeles
    So how much for just one bottle would be cheap? And how is Castrol Edge?
  6. JC91006
    16,923
    8,634
    If you buy oil in a 5quart jug, the price will range from $20 to around $28 at most online retailers (walmart, amazon). All the synthetic oils will be very similar and will work with a Prius (not a performance vehicle). So just choose the cheapest one with the correct grade you want and go with it.
    The 3rd generation Prius uses 0w-20 oil, some have increased it to 5w-30 like the 2nd generation. But very few Prius cars will be able to use a 5w-40 grade without damaging the engine (too thick of oil)
  7. nudriver
    nudriver Member
    283
    32
    los angeles
    I'm using the thicker stuff because my mechanic recommends it due to my piston rings being messed up. Go figure. How much more do you have to spend at an auto parts store on oil typically?
  8. JC91006
    16,923
    8,634
    I think the local parts stores run a special price for oil and filter together for about $37. I'm not sure you should be using a mechanic that would recommend a 5w40 oil for a car designed to use 0w-20
    ASRDogman likes this.
  9. nudriver
    nudriver Member
    283
    32
    los angeles
    I have to trust him. I've been doing it for a couple of years and the car runs fine.
  10. JC91006
    16,923
    8,634
    I'm curious which shop you go to in Los Angeles?
    mikey_t likes this.
  11. nudriver
    nudriver Member
    283
    32
    los angeles
    That would give away my anonymity here. LOL.
  12. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Mobil 1 or Pennzoil platinum euro 0w-40 is what I would get. Ranges from 25-30 for 5 qt at Walmart.
    douglasjre likes this.
  13. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Right. These cars in the rest of the world blow up left and right because that grade oil is too thick for them.
    edthefox5 likes this.
  14. JC91006
    16,923
    8,634
    They won't blow up. You'll probably see more engine wear, but with the turd gen cars, it probably wouldn't matter as the head gasket failure will take out the engine right about the same time.
  15. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Funny. I have better oil analysis results with 0W-30 then I do with 0W-20. Somehow I doubt a 40 weight is gonna magically cross the line to premature wear.
  16. JC91006
    16,923
    8,634
    The oil debate will go on and on and on. There is no right answer, the right answer is the oil you choose to use in your own car.
  17. ETC(SS)
    7,455
    No such thing as 'premature wear' in a 10-year-old car.... :ROFLMAO:
    Noahdoge and jerrymildred like this.
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    This might be a quicker way to get the answer to the original question than asking us and opening up yet another oil debate. :D
    Just try this magical new way to get answers.
    Interestingly, the first answer I got is in Rupees. :LOL::ROFLMAO:
    Noahdoge, JC91006 and mikey_t like this.
  19. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I would suggest HybridPit in Anaheim if you need any serious work done (just got a rebuilt engine from them), or Olive Auto in Burbank for regular maintenance. I would also suggest trying BG EPR to clean up your rings and engine gunk. It lowered my oil burning rate from a quart every 3000 miles to a quart every 5000 miles for a while. How many miles are on your car?
    Another member here used BG EPR to clean up his engine and upped his oil to 5W40 to lessen the oil burning on his Prius and it kept his car running smooth until he traded it in. Though his engine was in otherwise decent shape already.
  20. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    If I didn't care at about maximizing mpg, lived in Los Angeles, and wanted the smoothest/quietest running engine, I'd be running Euro 0w40.
    Mobil 1:
    Pour point: -51 0w40 vs -42 for 0w20
    40°C viscosity: 69 0w40 vs 43 0w20
    100°C viscosity: 12.9 0w40 vs 8.1 0w20
    Flash point °C: 232 0w40 vs 225 0w20
