T Battery Code Help
Discussion in 'Gen 2 Prius Main Forum' started by Cryptogram, Jun 7, 2018.
  1. Cryptogram
    Cryptogram Junior Member
    Indianapolis
    Purchased a 2005 Prius two years ago. It was in limp mode and codes were ( P3013 Block 3) & P3018 (Block 8) weak. Replaced 4 cells, reset codes and drove 20k miles with no issues.
    Now the car gives the P0A80 (Replace hybrid battery) code. After resetting the code it soon reappears after a day or so.
    Question, how do I get the system to throw the battery cell codes again. I am in hopes of just replacing out of range cells instead of the whole unit.
  2. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Rather than waiting for a code to be thrown, do a little more investigation. Get TechStream and start monitoring the voltage of each block. See what's happening dynamically.
    goku9384, Raytheeagle and SFO like this.
  3. Cryptogram
    Indianapolis
    Just got the Techstream in the mail this week however there is something fishy with the passcode or I am doing something wrong.
    It won't let me in!
    Thanks for the direction.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Did it come with a text file that has 32 “1’s” followed by something like 52115 then about 8 more “1’s”?
    Did you copy the Techstream file and overwrite the program file?
    Did a video come with the Techstream cd?
    What version of Techstream?
    Keep us posted (y).
    SFO likes this.
  5. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    You can repair a battery, but the other cells are still old.
  6. Cryptogram
    Indianapolis
    What does it mean to replace the mainmenu.exe ?
    Yes that was the passcode a bunch of 1's then50000170.... IT does not work. Version 12.20.024
  7. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    The video that usually accompanies Techstream and the mini vci driver show how to replace the Techstream executable file;).
    If not, google the version of Techstream you have and you’ll get an install video:).
    Give that a try, then look into the COM ports to ensure the computer recognizes the device;).
    Good luck and keep us posted (y).
  8. Cryptogram
    Indianapolis
    That was the problem. My media player wouldn't play the video.
    Raytheeagle likes this.
  9. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Do you have another device that can play the video:whistle:?
    The ones online are the same ones that come on the cd;).
    Keep us posted (y).
  10. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Raytheeagle and Mendel Leisk like this.
  11. Mendel Leisk
    42,132
    #11 Mendel Leisk, Jun 9, 2018
  12. Cryptogram
    Indianapolis
    Finally got the TS installed. So simple I am ashamed to admit.
    It showed the failing battery cells in the 2001. Now ready to reinstall the rebuilt HV battery.
    Thanks for the encouragement on the Techstream. Just what I needed.
    Update soon.
    Mendel Leisk and Raytheeagle like this.
  13. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Good to hear you finally got it;).
    While a challenge, now you have the best tool possible for the next steps :).
