T-SB-0076-13 : Glove Compartment Rattle over Rough Roads
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by DanManTX, Jun 16, 2013.
  1. DanManTX
    DanManTX Junior Member
    T-SB-0076-13 : Glove Compartment Rattle over Rough Roads (June 4th 2013)
    Some 2012 model year Prius C vehicles may exhibit a ticking noise coming from the glove box when
    driving over rough roads. The glove compartment has been revised to address this condition.
    This bulletin applies to vehicles produced BEFORE the Production Change Effective VINs shown
    below.
    PLANT PRODUCTION CHANGE EFFECTIVE VIN
    TMEJ Iwate #1 JTDKDTB3#C1017738
    TMEJ Iwate #2 JTDKDTB3#C1516938
    Warranty Information
    OP CODE DESCRIPTION TIME OFP T1 T2
    550101 R & R Glove Compartment Door Assembly 0.1 55550-52320-C0 91 40
    Parts Information
    PART NUMBER PART NAME QTY
    55550-52320-C0 Door Assy, Glove Compartment 1
    Dylan Murphy likes this.
  2. rjdriver
    rjdriver Active Member
    410
    170
    Rhode Island
    Hmm... Can someone clarify something for me? My VIN is constructed slightly different than the above examples. It has an "X" where the number or pound sign (#) is after the TB3 above. My first 8 characters match, and my last 7 numerical digits fall in between the two above, and I don't know where the preceding digits TMEJ Iwate #1 and #2 come from. Can't find that on any of my documents.
    Can anyone shed any light on whether I'm in the group. I definitely have an occasional rattle coming from that area on bad pavement, but thought it was the dash panel above.
  3. col127
    col127 Member
    345
    Illinois
    So how do you know if you "qualify or not"? My last 7 digits are:
    1013131 - all my characters before match up - too ! At the # - what's that supposed to be?
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I believe the # is the year... but I'm probably wrong. But it looks like yours is not inside the number.
  5. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Mine are between the two "TMEJ Iwate".
    So I assuming that I'm one of the ones to replace it. Right?
    ztanos likes this.
  6. PriusInParadise
    180
    91
    Hawaii
    TMEJ stands for Toyota Motor East Japan.
    Iwate is the name of the prefecture where the plant is located.
    #1 & #2 indicate the production line number.
    The "#" in the VIN are placeholders for a character that is not relevant to this TSB.
    So, the vehicles manufactured with VIN JTDKDTB3#C1017738 or later from line #1, or JTDKDTB3#C1516938 from line #2 already have the updated part.
    If the 12th digit of your vehicle is a "0" and the remainder of your VIN is less than 17738, or if the 12th digit is a "5" and the remainder of your VIN is less than 16938, your vehicle may be affected.
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Ah, so his was affected and I read it wrong... it helps if I read the instructions before answering the questions... always did fail on that part of the quiz, lol. Col127, you are part of this as your car was before.
  8. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    This is quite confusing....
    Got2bHam likes this.
  9. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    So If what you said is correct and following you all models between JTDKDTB3#C1017738 - JTDKDTB3#C1516938 are the affected ones right.
    Anyway I went to the local Toyota dealer to verify this, the first question they asked was "Where do you get this?" je je.
    Then they do some research and calls, they said that yes I'm one of the affected ones, but they have to verify my vehicle first in order to proceed with the bulletin.
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    No, he was saying that it was before those numbers on the 2 assembly lines.
  11. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    ok get it.
  12. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I may just print this out and when I go in for my 15k service I'll have them check it out.
    ztanos likes this.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Check your door tag. It's pretty easy when you have the tag sitting in front you these numbers. If yours is the number mentioned above or higher, you are good. If your number is below the numbers above, you need to get them changed.
  14. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Ok I will do it in the morning. Thanks.
    ztanos likes this.
  15. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    If you still can't figure it out, just post your numbers. We'll let you know. :D
  16. wmo168
    wmo168 Member
    239
    50
    South Florida
    Mine said C37 does that mean I am line #7 and not cover?
  17. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    JTDKDTB3#C1516938
    Where is the 37 located? Is it literally C37? If so then you have the newer part and don't need to worry.
  18. wmo168
    wmo168 Member
    239
    50
    South Florida
    Mine are 2012 - JTDKDTB37C1030xxx so am I need repair or not? Sorry it was not C37 it was 37C ...
  19. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    From my understanding, you are good. You are line 1.
  20. wmo168
    wmo168 Member
    239
    50
    South Florida
    :-( bummer mine still make noise from time to time
