T-SB-0076-13 : Glove Compartment Rattle over Rough Roads
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by DanManTX, Jun 16, 2013.
  1. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    That's because everything is plastic. :) Try turning the rubber bumpers in the box itself. Some people have said that it changes the dynamic and reduces the noise... be advised, this could go the opposite as well at which point you would just need to spin them again.
  2. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    How do I tell if my car was built on line #1 or #2?
    My car is s VIN is ...C150xxxx, so it is below the VIN for Iwate #2.
    Thanks.
  3. firstrival
    firstrival Member
    102
    My 2012 was manufactured in 9/2012 and it is well after the Iwate #2 VIN.
  4. col127
    col127 Member
    345
    Illinois
    I updated my box and it still makes sounds over rough roads. sigh. I don't know if they did a good job installing it or what. I actually have to press my hand on the glove box and it stops making any kind of sounds.
  5. maddog61
    maddog61 Junior Member
    44
    I just placed 4 small round strips of one sided foam near the glove box latches and on top portion of dash. That has stopped 99% of the rattles
  6. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    Has anyone else change the box and still had the rattle or did it go away?
  7. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Well that's great, I just randomly stumbled upon this, only to discover I was under warranty at the time when this TSB came out, but never received it (my number is about 2000 less than the C1516938 limit, never received this in the mail or was told about it at the dealership). I do have the 125k platinum VSP extended warranty, would it be worth it to contact Toyota to see if the extended warranty would cover me?
  8. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Might as well give it a shot.
  9. pulltab
    pulltab Junior Member
    26
    Poway, CA
    2015 Prius c
    Taking my 2015 Prius C One into the shop this upcoming week because of a loud squeaking from the glove box proper. I changed the cabin filter a couple of months back and then picked up the noise.
    A service Toyota mechanic rode with me and said there was something wrong internally with the glove box, i.e. plastic structural problem or something "not right"....
    The dealership has scheduled a complete box replacement.
    TC400 likes this.
  10. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    I spoke with the service advisor when I was in for my other Prius, and he showed me that the computer didn't reveal any TSBs available on my Prius C, even though my VIN falls into the category of this TSB. Oh well.
  11. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Contact another dealer...
  12. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    I'll do that when I get a chance. The service rep didn't seem to be trying to pull a fast one on me or anything. He showed me on his computer where it shows the available TSBs and recalls based on my VIN number, and it didn't come up. He did tell me that unlike recalls, they don't mention TSBs unless a complaint is made by the customer. I don't know enough about TSBs vs recalls to know if this is true or not.
  13. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    That is true. That's how I got mine fixed there was a TSB I complained it was fixed. Of course they had to order it in.
  14. pulltab
    26
    Poway, CA
    2015 Prius c
    Dealership put in another glove box, but did not solve the problem, still plastic vibrating against each other somewhere. They tried sanding/drilling/trimming... and put in some padding... it is 90% less noise.... I can live with that....
    TC400 likes this.
  15. Flys-Lo
    Flys-Lo New Member
    Ohio
    2016 Prius c
    Hate to resurrect a 6 month old thread - BUT - I have a 2016 Prius C3 with 1,000 miles on it and there is an annoying squeak over mild to hard bumps. Living in Ohio that's every 10 feet. The noise subsides with the glove box door hanging open. I'll be visiting the dealer tomorrow to discuss. Wish me luck.
    TC400 likes this.
  16. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    This is how I corrected the annoying squeaks emanating from my glove box door.
    I bought a tube of silicone grease (paste like consistency) and lubed all the contact points around the glove box, especially the latching area.
    All of the squeaks are gone and have not returned.
    It took me two annoying years to figure this solution out.
    Merry Christmas!
  17. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Best of luck!
  18. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    It's plastic on plastic, it will rattle some. I've noticed this but after inspection there's really not much you can do. I'd suggest putting some soft surface piece (felt pad maybe?) where the glove box tabs touch. Otherwise, I'd say crank the volume up a little bit more
  19. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    my 2015 C glove box just started doing this, it seems worse with load of the manual in it, still the little squeak is annoying
  20. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    Get some weatherstriping material that is usually used on the front door of a house. It has solved the problem for me.
    priustexasbob likes this.
