Tactrix open port help
Discussion in 'Gen 2 Prius Technical Discussion' started by Figster10, Jan 23, 2020.
  1. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I have purchased the tactrix open port but can't seem to get access to smart key to register used sks fobs to gen 2 prius.
    Question: which version of techstream works best with the open port in terms of getting access to smart key programming for USED KEY FOBS?
    Possible solutions:
    I have heard that using different versions of techstream helps but I need to know which is the best for the SMART KEY ACCESS fix
    note: I just need access to smart key programming for used fobs
  2. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    I don't believe there is a lot you can do without proper level security access.
    Raytheeagle likes this.
  3. ChapmanF
    18,547
    I think the normal access is fine for pretty much all of the fob registering and deleting operations. The security-professional level is for completely reseeding the car in case all the original fobs have been lost.
    But the thing with used fobs is that the normal procedures don't work with them. You can either get the used fobs revirginized, which then lets you use the normal procedures, or you have to proceed as if you were reseeding the car and re-registering every fob. Which normally requires the locksmith-level subscription; someone may have found alternatives, but I'm not knowledgeable about them.
    strawbrad and Figster10 like this.
  4. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Okay. I can do everything but reseed for used fobs and all keys lost. I guess the next question is: is it just with the gen 2 Prius that it does this with?
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    No, the restrictions on the Smart Code Reset feature of the Toyota Techstream software aren’t specific to Prius cars or certain model years. As far as I know, all versions of Techstream, regardless of version number or source, require you to have some means—not provided in Techstream itself—to compute the pass-code number to enter when Techstream displays a vehicle-specific seed number during the reset procedure.
    I’m aware of three ways to get pass-code numbers:
    • Anyone can buy a pass-code calculator program or calculation service from third parties, as mentioned in several PriusChat threads; like @ChapmanF, I don’t have any details of these to share.
    SFO likes this.
  6. Salvage09
    Salvage09 Junior Member
    38
    Pasadena CA
