Tail light fuse blowing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seekerhiker, Oct 30, 2020.
  1. Seekerhiker
    Seekerhiker Junior Member
    Connecticut
    I just picked up a 2012 Prius 2. It has been in some sort of a minor/moderate front collision as the bumper cover is a bit askew and the headlight assemblies are cracked.
    I suspect this has something to do with the #30 inside fuse blowing as soon as it is plugged in with lights on.
    On a quick glance up front it looks like the marker lamps (same circuit) are plugged in with no obvious cutting/melting/fusing of wires. Is there something that screams out as a likely culprit?
