Tail light trouble
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gary Lieder, Feb 13, 2018.
  1. Gary Lieder
    Gary Lieder New Member
    I have a 2008 Prius. Both tail lights went out about a week ago. Bulbs are good. Fuse is good. All other lights are working including license plate lights. Checked bulbs and fuse with volt/ohmmeter and have continuity.
    I have viewed other threads and none seem to have my problem.
    At a loss. Any ideas out there?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Rare question on this site.
    Answer these.
    Is the car a salvage title?
    Do you park the car outside and see signs of rodents?
    Mice love to chew on Prius wire. Take the cabin ac filter out see if any mice activity. If no rodent evidence got to be the relay.
  3. padroo
    padroo Senior Member
    2,763
    2,250
    I had trouble with my tail lights on my Prius from the time it was new. It was a bulb burnt out or a bad connection at the bulb housing.
    Yours may be different, inspect the bulb housing and make sure it is clean and doesn't have any green stuff on it. Don't spread the connection where the bulb sets while troubleshooting.
    Do you brake lights work? I'm thinking the tail and brake like share a common ground.
    #3 padroo, Feb 13, 2018
  4. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Was going to mention that but op says they went out together and has a voltmeter. That’s rare on this site lol.
    But could have rotten sockets on both sides. Mine have been perfect but have been lubricated early in its life.
    padroo likes this.
  5. padroo
    2,763
    2,250
    The license plate lights are usually tied into the tail lights but not positive on your Prius.
  6. Gary Lieder
    I'll check the sockets for corrosion. I'm also thinking if I check the sockets for continuity I should see a circuit to the fuse and back.
    If I don't see anything it could mean an open in the wiring, then I have a real problem. Will get back on this.
  7. Gary Lieder
    Two license plate lights work.
  8. Gary Lieder
    Will check sockets for corrosion.
  9. Gary Lieder
    Sits out but not where mice can get at it. Where is this relay you mention?
  10. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Sits out is all they need. Spend 10 minutes and look around. In the spare tire hatch in the cabin filter
    In the engine air cleaner housing. Mice damage is very common on a Prius.
    The relay is in the black plastic fuse box in the engine compartment on the right. Same box that has the battery jump points. Make sure all relays are seated.
    Can’t find my Prius manual right now misplaced it or would tell you which one it is. Says it on the cover though.
  11. Gary Lieder
    Good idea about lubricating, thanks.
  12. edthefox5
    10,096
    4,795
    Clearwater, Florida
    When I rebulbed the whole car I put grease in the sockets. Prevents galvanization. I use 100% Ester synthetic wheel bearing grease. Hi temp stuff. Do not use Dino grease in a few years it will corrode.
  13. Gary Lieder
    I'll check it out tomorrow and let you know.
    edthefox5 likes this.
  14. padroo
    2,763
    2,250
    A basic test light is a great tool for troubleshooting lights, it's what the truckers use.
