tail lights dont work at night but brake lights do
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by phil ross, Jul 12, 2020.
  1. phil ross
    phil ross New Member
    dallas
    not sure what to do, would like to fix this on my own. all the lights work in my tail lights but both of them do not work as tail lights at night when we have the lights on
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    Have you already checked the appropriate fuse?
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    "tail lights don't work at night"
    Do the tail lights work during the day? If so, that's a weird one, because there's no light sensor that I know of, and I can't think of a reason they would work during the day and not at night.
    #3 egg_salad, Jul 13, 2020
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Make SURE that you don't have the headlight selector set to DRL !!
    That setting turns on the headlights at reduced brightness but NOT the tail lights.
    (Yes, I've done that a few times.)
  5. egg_salad
    545
    426
    Las Vegas, NV
    I don't think there's a DRL setting on a US-spec '05
    SFO likes this.
  6. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    Your post does not make much sense. Would you care to explain it in more detail?
    How can all the lights work in your tail lights, but not work when the lights are on?
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    OK, back then I think that DRLs were still required in the US......so maybe they were "automatic" in the OFF position.
    Then that would mean that his headlight switch, or it's associated circuitry, is NOT turning ON like it should.
  8. egg_salad
    545
    426
    Las Vegas, NV
    I don't know what year DRL became a requirement in the US, but my '08 does not have them, and they are mentioned in the manual as "Canada only".
