Tail lights Replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by trvlmscl, May 2, 2023.
  1. trvlmscl
    trvlmscl Junior Member
    Tempe, AZ
    Hey my roommate just found the plastic clear lens cover for my 2010 Prius. Passenger side. Ugh. Not sure if the adhesive finally gave out after 13 years? But I think I would rather just order both sides and update it to 2012+ style. Is it a direct replacement or will I run into any issues?
  2. Tombukt2
    Tombukt2 Senior Member
    13,878
    2,521
    Durham NC
    No I think the 12 and up same body will swap right out My 2010 has 13s in it the lines looking instead of the dots however you want to describe them they screw right in and should plug right up I don't think there was any changes to the plugs I can't honestly remember.
