Take showers downstairs?
Discussion in 'Environmental Discussion' started by burritos, May 1, 2012.
  1. fuzzy1
    10,713
    Some dishwashers can boost the water temperature.
    Another case of contradictory legal mandates.
    For burn safety for children / elderly / not fully adult competent, my state law requires that domestic hot water heaters be set no higher than 125°F when installed, and when unit occupancy changes. Occupants are free to push the setting higher, but installers and landlords mustn't do it.
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Factory default for Takagi instant heaters is 122f. My newish Sears 30gal short tank has 108f as default setting. Above 130f mineral slag and scale start to form or build up.
    140f minimum for food service chemical sanitized dishes. 180f if using just hot water to sanitize. No way you can hand wash at 140f or even maintain that temp in the sink for very long. Looks good on paper or at some lab but just doesn't work in the real world.
    "For burn safety for children / elderly / not fully adult competent, my state law requires that domestic hot water heaters be set no higher than 125°F when installed, and when unit occupancy changes. Occupants are free to push the setting higher, but installers and landlords mustn't do it."
    There should be or is a dual requirement to have temp regulating mixing valves so you can have the high temp and be scald safe at the same time. That said I have yet to see a plumbing guy do the installation temp adjustment for these properly. Fingermometer and/or just screw the handle on and forget it.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yes, some can. But why don't all of them? Then the domestic water could be set at a safer temperature that would prevent scalding, and we'd all be healthier and use less energy. Sounds like an obvious solution to me. I wonder how many years it will take to either educate the population, or have it mandated into law.
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
  5. soup kitchen
    soup kitchen New Member
    30
    san diego ca
    You are really concerned about taking a shower upstairs? Wow
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I installed my water heater on the back of the shower enclosure upstairs, there is less than 3 feet of pipe to the valve, then about 3 feet to the shower head.
    Yellow is gas, Blue/steel is cold, Red is hot, White is Pressure relief, grey is the line to the shower head/faucet
  7. NiHaoMike
    NiHaoMike Member
    98
    16
    If you have city water, there should be enough chlorine to kill bacteria. It's a valid concern for well water, however.
    In any case, if you're worried but still want to save energy, you can rig a controller to heat it up to 140F a few times a week (perhaps an hour or two before you normally use the dishwasher), but drop it to a lower value like 110F most of the time.
