Taking a chance on an AliExpress Head unit.
Discussion in 'Gen 3 Prius Audio and Electronics' started by mhdriver, Sep 23, 2023.
  1. ASRDogman
    ASRDogman Senior Member
    7,562
    3,902
    Catch up!:confused::eek:o_O:cautious:
  2. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    They pay a company in India to do those reviews for them
  3. douglasjre
    2,177
    717
    Null, NL
  4. mhdriver
    mhdriver Member
    66
    26
    florida
    I've seen the one's Amazon is selling. Hoping the additional memory will make a meaningful difference. Can you supply a link of the one you bought?
  5. mhdriver
    mhdriver Member
    66
    26
    florida
    I'm sure there's some of that going on. Lots of junk on Amazon with good reviews. But there are a few people here and on other discussion boards that are reasonably pleased with these units.
  6. douglasjre
    2,177
    717
    Null, NL
    I guess you can try aftermarket on non critical stuff. I've been burnt over and over with aftermarket crap. Can u tell?
    mhdriver likes this.
  7. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    here’s the one I have in mine
    AWESAFE Car Radio Stereo for Toyota Prius 2010 2011 2012 2013 2014 2015, 9 Inch Touch Screen Head Unit Built in Carplay Andriod Auto Bluetooth Navigation Video Player https://a.co/d/ez8yoYa
  8. mhdriver
    mhdriver Member
    66
    26
    florida
    Can you elaborate a bit more on this?
  9. douglasjre
    2,177
    717
    Null, NL
    I put an eBay head gasket in a customer's car. I immediately afterwards had to eat the job as I had to redo on my hands. 16 hours plus $100 in fluid. When you're not excited about doing a job, it takes more than 16 hours
    Cheap plastic brake master cylinder which is injection molded. Probably 3D printed. It lasted 2 hours cracked dumped its contents all over the motorcycle causing the brakes not to work. Almost resulting in death
    Chinese brake pads that are glued onto the backing plate and separated. Because after all how do you remove glue? Same way you remove loctite you heat it. What a novel idea. Let's glue our brake pads onto the back end plates
    Chinese screws with a thread pitch not as specified
    Aftermarket screws on CFM jet engines are currently causing a320 to come out of the sky. Check NTSB on this one
    Chinese 12 volt multi plug interrupted the can bus system on a Prius causing the car to throw all kinds of error codes pop fuses and be disabled
    Chinese OBD2 Bluetooth dongle caused error codes and two cars. I immediately afterwards destroyed it with a hammer
    People from China can elaborate in greater detail because they know that the government is so oppressive
    I have too many stories of Chinese parts.
  10. douglasjre
    2,177
    717
    Null, NL
    Dup
    #30 douglasjre, Oct 8, 2023
  11. douglasjre
    2,177
    717
    Null, NL
    He didn't buy a Chinese car. And why is that? So why are you putting Chinese parts in your Japanese car?
    You know that lots of these spark plugs that say NGK on Amazon are actually fakes? Why would you trust your engine with ceramic being dropped into it?
    Why would you think you're saving money on an oil filter when you're risking your engine? Because when the glue that holds it backing plate goes through the motor.
    People think they're saving $20 on a part, but they forget what their time is worth. And worst of all Chinese brake rotors have soft spots. So it pulses just like if it were warped. Why would you risk your life with this stuff?
  12. douglasjre
    2,177
    717
    Null, NL
  13. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    what do you mean? You asked for a link to the item I bought. That’s the link
  14. mhdriver
    mhdriver Member
    66
    26
    florida
    What you like about it, don't like about it. How is the glare, any better than the original head unit.
  15. w84me
    w84me Active Member
    144
    224
    16
    Sacramento
    I posted some views on post #17 of this thread. There is glare when the sun hits it.
  16. douglasjre
    2,177
    717
    Null, NL
    I've seen Chinese parts set a car on fire. I tried to save you. I'm leaving this chat
  17. prius2010II
    prius2010II Member
    269
    23
    us
    I'm happy with my Ali unit. PP made a good point. A bad device from China can have a lifespan just over your dispute period. Some can either be dangerous. Ali reviews are of little value. Some lie about specs. Use a stock photo instead of photo from the HU they're selling you. Some sell fake Android units. Hacked to display a higher version of Adroid then the software really is.
    What I did. Researched
    Android Head-Units | XDA Forums
    I bought a Klyde unit.
    Posters post on firmware upgrades. What issues they have. Solutions.
    I wanted a prius specific HU. Buttons on the side. A regular 2DIN unit, I would have bought something like a Kenwood. Buy a closeout model if you want to save money.
    edited to add Posters advised using a USB thumb drive and not SD memory when upgrading firmware. The memory card reader on my HU is reported to be extremely low quality.
    One example of what some of the PP are implying
    #37 prius2010II, Oct 22, 2023
