Taking off the hitch every winter, will it damage the bolt hole?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kikik, May 24, 2018.
  1. kikik
    kikik Junior Member
    83
    44
    Maine
    Cool, I wonder if it stains the road pink? :)
  2. kikik
    kikik Junior Member
    83
    44
    Maine
    I think I need to do this. I like that it dries to film. Thank you!!
  3. Mendel Leisk
    41,457
    There's myriad automotive products too, that go on liquid, then gel, form a film. not sure how they'd compare to linseed oil. I've coated an outdoor cedar table with linseed, I think that sort of thing is it's traditional application. But who knows.
    Here's one commercial example, I haven't tried it though:
    kikik likes this.
  4. Mendel Leisk
    41,457
    @tvpierce I had some boiled linseed oil, and a foam brush, so I did the rear axle, trailing arms and sundry yesterday. Took the plastic covers off, the ones that cover the traling arm links, also the rear wheels. Also loosened a few of parking brake cable brackets for access. Had it jacked up and on safety stands, took a couple of hours. Checked it today it's tacking up pretty good, looks nice and shiney. (y)
  5. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I've used a foam brush before too -- simply because that's all I had. It worked OK, but a conventional brush seems to get in crevasses better.
    Boiled linseed oil is an old farmer trick. Was used to protect farm implements and such. I'm told it's the prominent ingredient in rust protection services -- like Ziebart.
  6. kikik
    kikik Junior Member
    83
    44
    Maine
    Did it dry clear? Or is it more like light brown/yellowish? The link you showed me seems like it's a light brown color. Contemplating which one I should get...
  7. Mendel Leisk
    41,457
    The linseed coating ends up slightly golden, I think. Most of what I costed was black painted.
  8. Mendel Leisk
    41,457
    This is 4~5 days post application, it looks wet but isn't. Not tacky feeling.
    kikik and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    If you ever need to do those back hub assemblies, you’ll be in for a treat:cool:.
    Have the rust penetrating solution at the ready(y).
  10. kikik
    kikik Junior Member
    83
    44
    Maine
    COOL!!
    I have rust inside the wheel I wish I'd known it would rust in there. Actually I wish I'd known to do these preventives when I first bought it brand new right out of the dealer. It was my first time ever actually looking under a car when putting in the hitch.
    After that I actually thought of buying a lift lol!! It MAKES you want a lift so you can go under the car and do whatever you feel like doing.
    Raytheeagle likes this.
  11. Chazzman
    Chazzman Junior Member
    IMHO (in my humble opinion), you're losing an awful lot of sleep over nothing.
    Loctite is sort of akin to putting a very thin layer of latex paint on the threads. It will keep the pieces from coming apart by themselves, but still allow you to snap them apart with hand tools, breaking a light seal.
    You're worried if these metal pieces will wear out. Yes, they will. In about 100 years. Unless you have some really extreme conditions (a lot more than just a little salt and snow) you might be better off just finding some replacement bolts and throwing them in the glovebox, just in case you ever need it, and for your peace of mind.
    I really like Maurice's idea of just leaving the bolts in the holes year-round. You can't really wear out metal bolts during your lifetime by taking them apart twice a year. In fact, taking them apart twice a year is what will make them last even longer, since they'll never have a chance to seize up.
    kikik likes this.
  12. Mendel Leisk
    41,457
    Work safe, always use jack stands. I like also an "insurance policy": a tree stump section, about 13" diameter and about the same length: I just push it under there first. It's thicker than me. :)
    priusrust, padroo and kikik like this.
  13. kikik
    kikik Junior Member
    83
    44
    Maine
    I used 2! One that I bought that pumps it up and 1 that came with the car :)
    But thats a good tip on sliding something under, thank you!!
    Raytheeagle and Mendel Leisk like this.
  14. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Looks good.(y)
  15. Pdaddy
    Pdaddy Member
    160
    49
    It's for locking bolts in place so they don't come loose.
    SM-G920V ?
  16. padroo
    padroo Senior Member
    2,763
    2,252
    If you use a thread lock like Loctite you want the threads clean and dry, no oil. If you choose to just lubricate the threads no Loctite.
    Like was mentioned, use the blue not the red. The red is permanent.
  17. kikik
    kikik Junior Member
    83
    44
    Maine
    Thanks, I didn't get a reply before my install so I just lubricated it. I don't think I want to lock it in there...it was hard enough as it is for me to unscrew and screw in the bolts...I don't want it even more harder. I had to get the trampoline bar again to tighten it having my son hold the wrench part to the screws and it kept slipping and it was like comedy lol!!
    My son kept asking, "Are you SURE you're suppose to use the trampoline bar?!"
    But good to know there's something like this in future projects :)
